HTT 62/65/13ss Owners - Feedback
Old Jan 7, 2009 | 03:05 PM
jgiachino's Avatar
Originally Posted by Brian Lent
I think it is a little small for 500 hp. I had a 62-65-12 which I know is smaller but I would hit 1600 degrees pretty fast and actually warped the housing. I heard alot of people like the 64-65-13 but have never tried it first hand. I would not go smaller than 62 71 13 or 14 for 500 +. My .02
My problem is i have an auto, otherwise id get the 62/71/13ss, but dont want the lag associated with the /71 & Auto. I did think about the 64/65/13, but errored on the side of smaller...i can always upgrade the housing to 64 for relatively cheap...and the long term plan is twins which i believe will work better with the 62/65/13....
Old Jan 9, 2009 | 04:25 PM
bigwheels94's Avatar
Love mine. I only haul a slide in camper, & I've only got it over 1400* once. That was passing a subaru on a 8% grade from 45 mph to 80 mph. I hit 1500+, but just for a few seconds. That was with TNT on SW-9.Normal DD I can only get to 1200*.
Old Jan 9, 2009 | 05:14 PM
ataboy9026's Avatar
bigwheels94..... does your exhaust ever drone? I am looking into a system and wondered about the 5" drone I hear about. I am leaning toward a 4" from Silverline. I will have very similar mods to yours when done. I have the turbo and Floor-it stage 2 pump here waiting to put on till spring. I just got my 75hp injectors from JL Machine installed and it gets pretty hot quick, it also can really roll the black smoke, sometimes even when I dont want it to.
Old Jan 9, 2009 | 08:56 PM
CoolumConst's Avatar
I wish mine would keep things as cool as you guys see. I think I am going to twins.
Old Jan 9, 2009 | 11:25 PM
Ataboy. Yeah, it drones. Kinda annoying. I may put a 51" muffler on it one of these days. The stock minus cat, & muffler droned too. I had a small muffler in place of the stocker, but it still droned.
Old Jan 10, 2009 | 12:56 AM
ldzielak's Avatar
I had a 62/65/13ss and upgraded to the 64/65/13ss when my engine was being rebuilt. I miss my 62, I have too much smoke down low towing just plain sucks compared to before. I think when winter is over I will send it back and get a 62 again. The top end is killer with the 64, but I need to tow and it's a daily driver.
Old Jan 10, 2009 | 12:58 AM
jgiachino's Avatar
How do you think the two compare in daily driving (no towing)?
Old Jan 10, 2009 | 07:15 AM
OT-OF-Here's Avatar
To small?!
Not at all.
Old Jan 10, 2009 | 07:32 AM
OT-OF-Here's Avatar
Drone
I ran a 26" Donaldson for maybe 2 years without any drone. I don't think the length of the muffler has anything to do with drone. There are a couple zillion threads on drone but primarily drone was found to be caused by varying things on different trucks. That's a lot of help,... right? There was a recall of a hose vibrating against something,...I think it was a power steering hose or a protective hose that went over it or something like that and that worked on some trucks. There was a fix on some trucks,... like mine where I added two extra clamps in front of the muffler and spaced evenly up to the down pipe,... my cat fell off and that was a lot of unsupported length so I went that route and it helped a lot but the final fix on my truck was the transfer case. They never told me the problem they found but they replaced the entire transfer case and that was the end of drone.
I know of others who found totally different solutions but that is what solved my drone problem.
Old Jan 10, 2009 | 01:49 PM
Tacsavage's Avatar
I really love my 64/65/13ss. It cools great and spools great. But it goes back to the auto vs manual. Manual, go 64, no problem. Auto I would lean toward a 62 unless you got plenty of fuel to help spool a 64 but it will be at the expense of smoke. Here is a dyno vid, everything set to kill (TNT/TST stack), but you get the idea on smoke. I did miss gear going into sixth so lost all rpms then hammered throttle. Tac
http://www.youtube.com/watch?v=wl8ltXPcEIo
Old Jan 10, 2009 | 01:54 PM
rip 112's Avatar
Hey Tac what numbers did you throw out on that run?
Old Jan 10, 2009 | 05:48 PM
Tacsavage's Avatar
It was a little low-509hp, no torque numbers. It was a mustang dyno so a lot of people were disappointed. I didn't have anytime to tune either so more potential there. I need cp3 and injectors now. Tac
Old Jan 10, 2009 | 09:23 PM
Maybe there are many kinds of drone. My drone is all exhaust note. About 2500rpm it starts to BLLLAAAAA. that resonates through the cab, & will get my ears ringing on a grade. I can live with it, but I would like to quiet it down some. Maybe someone could post a recording of "drone". I may have the wrong idea about it.
Old Jan 11, 2009 | 01:00 PM
Hintz's Avatar
Were was that at?
Old Jan 11, 2009 | 05:54 PM
Tacsavage's Avatar
Blowing Rock, NC. High elevation too.
