how they produce power?
I have done a little searching, but find conflicting answers.
How does the EDGE JUICE produce its power?
Is it adjustable in cab without the monitor?
If so how is it adjusted (toggle, dial, ?)?
Now I Have the same questions for the QUAD XZILL STD.
How does the power get produced?
Adjustable in cab w/o monitor?
If so how?
If anyone out there has tried both, which do you prefer?
If so how?
Standard Juice w/o monitor is 3way adjustable with toggle. 30/60/90hp timing, duration, and pressure if you have the 305/555 motor. Timing/duration only if 04.5+. Same with the Quad box. His does all three parameters also.
Gumby
Jul 23, 2007 04:47 PM
06dmc
19
Aug 9, 2006 12:54 AM
Commatoze
Jul 27, 2006 08:05 AM
