how to stack
Old Aug 5, 2005 | 09:06 PM
harleybill38's Avatar
how to stack
Hey guys, I have a powerpup and dont understand how to stack boxes. how do you do wire hookups or anything else with the first box.what should I stack with my pup?Also I have 3:55 gears how big a tire can I turn? what tranny upgrades do I need?Any good diesel performance shops around chicago?
thanks in advance,
2004 3500 dually 305 hp
Old Aug 6, 2005 | 05:59 AM
Dodgezilla's Avatar
First off, are you sure you have 3:55s? They were not available in an 04 from the factory. Only 3:73s and 4:10s. Sorry but I'm not sure about the stacking question with that particular module. I do know that it does matter which box is hooked up first so do a search on powerpup and I'd bet you'll find your answer if nobody else chimes in.....
Old Aug 6, 2005 | 09:34 PM
the sticker in the glovebox says axle ratio 3:55 coul it be a misprint?
my stacking question is do I download a 2nd box into my truck computer and does it recognize the pup and the 2nd box and work them together?what about the plugins in the engine bay?since the pup allready uses the plugs? confused.....
Old Aug 6, 2005 | 09:40 PM
RamWheelsBy4's Avatar
You can't "download" a second program into the computer. You can stack a performance box like TST, Edge Juice, Edge EZ or other performance boxes. They are not downloaders. They are external computer modules that plug into varius engine controllers and/or the computer itself and modify programming between the ECM and the varius controllers to increase performance.
Old Aug 7, 2005 | 01:02 AM
DieselRaptor's Avatar
As stated above, you don't "stack" per se with the BDDL. It is downloaded into the ECM. If you really think you want to add more "umph" to the DL'er, the RAMifier is great IMHO.
Scott
Old Aug 7, 2005 | 05:40 PM
Dodgezilla's Avatar
I could be wrong but I was pretty sure 3:55s were no longer available starting in 03. You may want to check the axle tag to be sure.....
Old Aug 7, 2005 | 06:31 PM
thanks, now I understand stacking,I looked and found no axle tags,I want to put 38's but I still need power to tow my bobcat and mini excavator.I did 105 mph towing my bobcat yesterday just to see what she can do, plenty left.What a huge difference from my 99 superduty.I love my truck.Maybe v.b. and t.c. next or should I just buy a aftermarket trans now.I want big power but still hold together.
Topper
Mar 3, 2008 10:17 AM
white250005
Oct 25, 2007 10:19 PM
smoky beast
Oct 18, 2006 06:58 AM
B.Law
16
Apr 22, 2005 02:28 PM
Cat Cracker
Jul 14, 2003 12:17 PM
