how safe is hot juice?
Old Jan 30, 2006 | 10:40 PM
razor6's Avatar
im thinking of sending off my juice to get it reflashed as the hot juice and was wondering how safe it is? from what i hear its safe and i dont need any upgrades beside air breather and exhaust. and how much more does the hot juice smoke? any suggestions?
thanks
Old Jan 30, 2006 | 11:25 PM
Big Horn's Avatar
I was also thinking of going to the "hot" juice and I have the same question. I think it is probably a symilar program to the Crazy Larry BD. What mods are guys running with CL? I believe the hot juice is around 180 HP and CL is 230 hp, anyone running either?
Old Jan 30, 2006 | 11:28 PM
Fred Swanson's Avatar
It is still smooth power. Not sure the stock turbo will like it though. I put one on an 05 along with a DTT tranny and a TAD B1-02-4 turbo, and it was just plain fun to drive on 5 all the time.
Old Jan 30, 2006 | 11:29 PM
hognutz's Avatar
hot juice is 180, CL is 200 I do belive. they both will require tranny/clutch help to be safe. I don't know what either of them is like egt wise but I have a feeling they will both run the egt's up noth most likely if you are stock. there are people running them on hear though someone will chime in.
Old Jan 31, 2006 | 08:31 AM
Argo's Avatar
I have only had the hot box for 4 days but have used level 5 one time to test it out. The egts only got up to 1150ish and the boost was up to around 38lbs. I just cruise around town on level 1 and when I want to mess around I use level 4. I will hold off on level 5 until I have more mods and level 4 isnt enough for me any more. level 4 is 100hp and level 5 is 180 so that is a pretty big jump. As far as smoke, it really isnt that bad compared to the stock smoke. If you are stock though I dont think(from hearsay) that you get the whole 180 hp out of it. The injectors arent enough to keep up with the demand and the lift pump isnt either or something to that effect. I am all stock except an air filter and not the hot box. on level 4 I broke under 15 second 1/4 mile yesterday according to the attitude box.
Old Jan 31, 2006 | 09:39 AM
B.Law's Avatar
How does the HJ make the additional power? More duration? More pressure? Or both? I hope not all of it is done in pressure...
Old Jan 31, 2006 | 09:41 AM
hognutz's Avatar
on the 04.5 and up it is supposed to just be timing and duration. on the 03-04 the normal juice uses some pressure so i don't know if it adds extra presure or not.
Old Jan 31, 2006 | 01:10 PM
Capp35's Avatar
From our last conversation....
Did you really pay the $300 to have it installed?
Old Jan 31, 2006 | 03:12 PM
Argo's Avatar
no, he dropped his price to match online pricing.
Old Jan 31, 2006 | 03:30 PM
Capp35's Avatar
I'm glad.
I hate to see people pay so much for installation, when it so easy to do it yourself.
Old Jan 31, 2006 | 06:57 PM
Argo's Avatar
regardless his origional price was $200 less than any other local shops were willing to do. he came down a couple more hundred though and came to my house and installed it in my driveway and showed me how it all worked.
Old Jan 31, 2006 | 10:21 PM
strokethis600's Avatar
you will probably need turbo, clutch, and an aux. fuel system. the stock fuel system starts to miss out around 100 to 120hp.
Old Jan 31, 2006 | 10:55 PM
razor6's Avatar
i prolly wont get a clutch or a turbo till they go out but i know i will probably need a aux fuel system but how much does a fuel system cost?
Old Jan 31, 2006 | 11:12 PM
haisley machine did mine, 425 + install= somewhere around 700. dont quote me, but they had never put their system on a common rail so they had to install it. other than that i would have installed it.
Old Jan 31, 2006 | 11:19 PM
razor6's Avatar
i just want to make my truck smoke more if anything... i want to do it by not spending a whole lot of money and i was thinking if i just got my edge upgraded it would smoke alot more. i dont tow anything above level 2 and if i ever put it on level 5 i just want to smoke for a little bit. so just to make it smoke a little but (no more than just a few min) and not spend a lot of money what should i do???
