How quick are these trucks supposed to be?
Old Jan 3, 2010 | 11:31 AM
BrewCity6Pack's Avatar
No boost elbow, the truck is completely stock besides the exhaust and programmer. I really expected a very noticeable difference when you're talking about adding 60-100 RWHP (80-120 crank) out of a tuner, but honestly its still a slug that gets smoked by SOHC neons.
My main question is...is this normal, or is there something wrong with my truck that it seems so slow?
Old Jan 3, 2010 | 11:34 AM
fordracing19's Avatar
Stock size tires?
Old Jan 3, 2010 | 12:26 PM
Originally Posted by fordracing19
Stock size tires?
Yes, running the stock tire size.
Old Jan 3, 2010 | 06:19 PM
Dave04600's Avatar
100hp is a night and day difference. Most likely you have a problem from what you describe. You should put a scanner on it to check your rail pressure. My truck was a total turd with bad injectors, runs like a corvette now. When I was in high school i had a friend with a 4cyl mustang that did 0-60 in 17 seconds. he would take hills in 3rd at WOT and loose speed. If that is the way your truck is running there must be something wrong.
Old Jan 3, 2010 | 06:33 PM
I don't have any problems climbing hills or anything like that, like I said the truck runs great and strong when not hammering on it
What should my RP be at? Have to check if the predator readsthat
Old Jan 3, 2010 | 09:51 PM
just went out and checked my RP's
Idle = ~4700-5100
WOT = ~21,200 - 23,300
Cruising @ 55 in OD = ~6520
Just doing a quick search around the boards, those numbers seem pretty good.
For some reason the truck seemed a lot more responsive tonight and got around a 10 second 0-60. I noticed when I'm testing my 60's, i'm not really hammering it, just rolling into the throttle which probably kills the times a little as well.
Maybe I'm just paranoid
Old Jan 4, 2010 | 02:49 PM
043500QC's Avatar
My 04 was a little sluggish on the top end to till I cranked the timing on it, then it was an entirely differant animal. Do a search on here for timing or roktec sensor. It worked for some but not others, but from what your describing, it sounds like your will benefit from that mod.
93-12Smoke
Oct 13, 2011 09:56 AM
guidster
33
Dec 9, 2004 07:43 AM
Suburbanite
Jul 19, 2003 12:44 PM
c5r
25
Mar 10, 2003 02:44 PM
