How much pressure to the CP3
Old Jun 4, 2008 | 08:45 PM
cameroneod's Avatar
I'm running 30psi. No problems so far.
Old Jun 5, 2008 | 09:43 AM
PEAKSTRYDE's Avatar
Originally Posted by Cummins610
Is 30-50PSI safe for the stock fuel fliter? I guess I should turn up my fass because it 15PSI at idle and 7 WOT
I wouldn't go much higher than 30 PSI with the stock canister LID, just to be safe I would get a billet lid if you really want to run over 30 PSI to prevent seepage or perhaps cracking or severe leakage with the stock plastic lid. Geno's has a pretty nice billet lid.
Old Jun 5, 2008 | 11:15 AM
banshee's Avatar
I run a belt driven MITUSA along with a Aeromotive boost referenced rising rate regulator and a billet aluminum fuel filter cap. I idle with 35psi and rise to 95-100psi at max boost. I've heard of the plastic ff caps blowing off in the 50psi range, so be careful.
Old Jun 5, 2008 | 12:26 PM
Hintz's Avatar
, that doesnt seem like the CP3 would like that much
Old Jun 5, 2008 | 12:56 PM
AlCorr's Avatar
I'm getting 18-19psi with the Carter pushing my stock pump on the filter. I'm thinking of getting a Holley Black to replace the Carter.
Old Jun 5, 2008 | 01:53 PM
banshee's Avatar
The dyno says it does. It's certainly not needed, but it does improve power. No leaks or any other issues either.
Old Jun 5, 2008 | 04:23 PM
paroxysym's Avatar
stock cp3, with my FASS HPFP 150 im running 21 to it.
Old Jun 5, 2008 | 05:36 PM
Nsomniac05's Avatar
i dont know why your still running the stock fuel filter with a FASS 150/150.... Wouldnt that be an unneccessary restriction when you have two fleetguard filters on the pump?
Old Jun 5, 2008 | 05:39 PM
Nsomniac05's Avatar
I say the cp3 wouldnt mind that but i dont know how the filter keeps from being blown to pieces at 100PSI fluid pressure and no tellin how many GPH.
Jethro6213
19
Jul 11, 2008 11:59 AM
PourinDiesel
15
Jun 16, 2008 09:51 AM
CTDinMT
Sep 2, 2007 04:05 PM
BADBOWTIE
28
Jul 14, 2007 02:36 PM
megacabrule
33
May 10, 2007 01:07 PM
