How much boost is too much on stock studs?
Old Nov 14, 2007 | 03:18 PM
LooseBoltsRob's Avatar
Originally Posted by cquestad
I ran 100k at 55-58 psi daily on the stock bolts...
Its drive pressure that kills um...not boost. With the right turbo(2) the OEM set up lives fine for a long time.
That makes me feel better. It seems like those who are replying to my post with personal experience have been fine with 50 psi or more. I'm going to leave it since only pushing 1200 degrees on EGT is nothing, so I'll take my chances.
Old Nov 14, 2007 | 03:52 PM
cquestad's Avatar
I would not run a 62 over 50 psi too often on OEM bolts. Way more drive pressure than a A5k.
Old Nov 14, 2007 | 04:07 PM
Just a few seconds here and there when occasionally rolling into 5th or 6th gear okay you think?? Like I mentioned, it never runs over 45-46 psi even in 6th on a full pass starting in lower gears.
Old Nov 14, 2007 | 04:35 PM
staarma's Avatar
I thought the Silver 62 was running a 71mm turbine in a 14cm housing. With a 62mm compressor that doesn't sound like the drive pressure would be out of whack at 50PSI or below. What am I missing. I would like to know because I'm running a HTT 62/71/13ss that's basically the same set to 47 PSI.
Old Nov 14, 2007 | 04:45 PM
jlibert's Avatar
I ran my silver bullet at 55 psi daily on stock studs for about 6 months with no problems. After I blew out a freeze plug with the beta program I decided I was probably pushing it and I ordered studs. But if you have the studs already, why risk it? Getting them in now is fairly easy compared to having to replace the head gasket and clean up a big oil and coolant mess.
Old Nov 15, 2007 | 07:05 AM
wap's Avatar
wap
I pushed my stocker over 50lbs a few times and mine lived but I agree with CQ, I would back off a little. The Silver 62 acutally has a 74mm wheel wich will help but what is 3-5lbs of boost really gona gain you? I keep mine down to 47-48 and have had zero issues so far. If you don want to do studs just cut the boost down a little, I doubt you will feel much of a diff going from 51-52 to 45-48. JMO
Old Nov 15, 2007 | 09:21 AM
Good idea...I will get around to installing the studs eventually, but it's a job that really should get injectors while you're there and after dropping a fortune on a new clutch, $1200 injectors aren't exactly getting ordered tomorrow.
Old Nov 15, 2007 | 11:37 AM
RamWheelsBy4's Avatar
I ran my SPS66 at 55psi with stock head bolts for a good while and lots of tracks runs before I added studs.
Old Nov 15, 2007 | 02:56 PM
03qclb5spd's Avatar
55psi here, stock studs.
Old Nov 16, 2007 | 06:59 AM
wap's Avatar
wap
Might as well do vavle springs while your there too, or at least thats something to think about.
Old Nov 16, 2007 | 07:32 AM
tcr's Avatar
tcr
50+psi for almost a year now on a little ol' 305/555 engine. 110,000 total miles on engine.
Old Nov 16, 2007 | 08:31 AM
Dwitt0187's Avatar
WHAT TURBO ARE YOU RUNNING I AM THINKING ABOUT TURNING MY BOOST UP ON MY 62/14 FROM 41 TO AROUND 48-50 WITHOUT PUTTING STUDS NO MONEY FOR THEM NOW BUT HAVE A ISSUE WITH EGT'S
Old Nov 16, 2007 | 08:46 AM
tcr's Avatar
tcr
HTB2 62/14, and I'm barely over 50psi. How high are your egts?
Old Nov 16, 2007 | 08:48 AM
tcr's Avatar
tcr
Ahhhh, I now see your injectors. Your sending alot of fuel to a 62/14, I'd say your undersized a bit.
Old Nov 16, 2007 | 10:11 AM
Dwitt0187's Avatar
IVE SEEN MY EGTS HIT 1700*
