How much boost from a Super B?
Old Oct 11, 2006 | 05:51 PM
stock03's Avatar
Question How much boost from a Super B?
Anyone know how much boost a Super B turbo should make? When I bought it I was told to expect almost 50 pounds. I don't have a boost gauge yet. Thanks for any responses.
Old Oct 11, 2006 | 09:25 PM
pullin hard's Avatar
my super B turbo, was waste gated at 44psi.
my TST box read 40psi, but thats all it went to, but i have other gauges, and the boost gauge would pull 44psi, and no more. if i would have played with the waste gate, i am sure i could have done more, but why.
that was fine for me.
anyway, the lower the power settings i ran, the lower the boost numbers.
Old Oct 11, 2006 | 10:26 PM
stock03's Avatar
Cool thanks for the response. I can't wait to get the boost gauge and know for sure.
Old Oct 12, 2006 | 04:24 AM
Dodgezilla's Avatar
45 is all I could ever get out of my HTB2 on my 03. You're probably in the same boat. You're not going to see high boost numbers unless you're putting the fuel to it regardless of your turbo....
Old Oct 12, 2006 | 07:43 AM
abc4yew's Avatar
The previous owner of mine was able to get 47psi but I've been able to get it above 85psi ks
Old Oct 13, 2006 | 03:10 PM
stock03's Avatar
85psi??? Wow! sounds like a lot. Wont that break something?
Old Oct 13, 2006 | 03:15 PM
signature600's Avatar
Pay no attention to him, He's got it as a top charger in a twinset
Chris
Old Oct 13, 2006 | 04:27 PM
Lightman's Avatar
According to BD, the super b is efficient up to 45psi, although it can handle higher pressures. Most are wastegated from BD between 38-40psi. Mine blows off around 39psi, haven't adjusted it. I like mine so far.
Old Oct 13, 2006 | 04:33 PM
abc4yew's Avatar
Chris has qualified for final jeapardy It's a good strong turbo that can flow alot through its tiny pie hole of an outlet. If you are heavily fueled you can get their Super B special....ks
SlingShot
Apr 4, 2011 08:05 PM
Diesel Dave2
16
Dec 20, 2008 07:11 PM
Buckshotmckee
Apr 19, 2005 07:20 PM
Cumminsdieselboy
Oct 27, 2003 07:36 AM
Wes C
Dec 24, 2002 12:28 AM
