how many auto clutches in an 03 HO 48re?
Old Jun 1, 2009 | 07:12 PM
1985cucv's Avatar
i was wondering how many clutches can be put in the 48re. i was reading a post that you can put 1 more in than from the factory is this correct? or is it only on the 47? how many actually go in there? any help would be greatly appreciated, as i plan on rebuilding my own trans input output tc clutches and bands thanks
Old Jun 1, 2009 | 07:49 PM
no_6_oh_no's Avatar
Four clutches is OEM, with the correct parts you can add 1 more.
Old Jun 1, 2009 | 07:51 PM
JFlory's Avatar
1st gear is 4 from the factory, but can be modified to hold 5. It takes some lathe work. Not something alot of people can do on their own.
2nd gear is a band.
3rd gear only has 4 from the factory. It can be built to hold 6 with realitive ease. Just use different clutch and steal sizes until you get it. A heavily modded tranny can hold as many as 7-8 3rd gear clutches.
OD holds 5 or 6 clutches. Seen both. Can be made to hold 6 if it only has 5.
OD direct holds 9 clutches.
Most increase in clutch numbers mean that the thick plate on the end has been turned down on a lathe to allow for another set of clutches and steals. This isn't something everyone has access to. It also means the builder needs access to an assortment of clutch and steal sizes, along with different size large snap rings. All of these things set at the correct tolerances.
J.D.
Old Jun 1, 2009 | 08:14 PM
1985cucv's Avatar
are the stock amount good enough for 550 horse?
Old Jun 1, 2009 | 08:43 PM
JFlory's Avatar
550hp used for what?
Pulling, towing, DD, drag, all??
Old Jun 1, 2009 | 09:38 PM
1985cucv's Avatar
daily driving a little towing
Old Jun 1, 2009 | 09:51 PM
JFlory's Avatar
The stock #'s should be good as long as you are using upgraded clutches like Raybestos high energy or something like that.
You should be able to get another clutch in 3rd gear fairly easy. You just need to get some smaller clutches and steals.
Don't forget to get some VB work done. Nothing will hold without some added pressure.
J.D.
Old Jun 1, 2009 | 09:57 PM
1985cucv's Avatar
thanks for the response i got the trans go in and all seems good i will be doing this in the future just want to get everything lined up for what i need
desertchecker
Apr 18, 2008 05:15 PM
CTDowerTN
Mar 28, 2007 09:04 PM
CTDowerTN
Jan 22, 2007 03:18 PM
Mostwanted
Nov 27, 2003 11:15 AM
