How to increase performance
Old Sep 14, 2004 | 03:20 PM
donwon9999's Avatar
I have a California 2003 CTD Truck. Stock is 235 Hp vs normal 250 hp.
I want to increase the performance of the engine but nothing crazy like 1/4 mile racing.
What would be the best logical steps to do this. I can't afford to do it all at once but more in steps. Is it best to start with air intake, exhaust, chips, etc. Not to open a big can of worms but what is the best chip for the job? Everyone seems to be going with the Edge EZ?
Also, what are the long term affects on the truck by charging up the engine?
I am not getting great mileage either. I am bringing it in to the dealer to check the injectors and pump. I can only get about 14-15 with combined city/freeway and not putting my foot into it at all.
Any suggestions would be great. This forum has been awesome so far.
thanks,
Don
Old Sep 14, 2004 | 04:47 PM
BigBlue's Avatar
I'd do gauges, exhaust, intake, fueling box of your choice (I like the EZ).
Old Sep 14, 2004 | 07:37 PM
hialtitude's Avatar
Same as above-except I like my six-gun better than my old edge.
More power down low.
Old Sep 15, 2004 | 12:55 AM
SuperGewl's Avatar
Install the Banks Six Gun w/Speed Loader. That's the ticket, it may cost more but I think it's worth it. I'm running it on my 235hp Cali truck and the power is nice. I only run it on 2-3 and I just love it. I'm not a racer so I won't even think about using it on 4-6.
Old Sep 15, 2004 | 05:38 PM
Car_nut57's Avatar
Start with Banks Monster exhaust. This exhaust comes with a true 4" DP that connects directly to the turbo and eliminates the cast elbow that necks down from 4" to 3.5". This really helps the exhaust flow smoothly out of the turbo. Also the muffler is one of the more restrictive areas and Banks new muffler incorporates an expansion chamber to avoid any exhaust drone.
Next you need a good air intake such as the Scotty RA-III with new 2-stage foam air filter element. These intakes get air from the stock fender location as well as ram air from the front of the truck. The foam air filter stops more dirt than gauze filters while maintaining great air flow.
You will also want a Turbo Air Guide (TAG) to help direct the air flow into the turbo for quicker spool ups and better fuel economy with less smoke.
Next its gauges like the Di-Pricol which were made spefically to match the new Dodge dash and a chip. Banks Six-Gun with the latest programming works very well and we have seen small mileage increases using it here in the shop on a 2004 truck.
Old Sep 15, 2004 | 09:32 PM
donwon9999's Avatar
Guys,
So far great info
With the CA truck will just doing the exhaust cause the Engine light to come on? I thought the CA trucks had cats on them to meet CA emissions?
Anyone know what power increases you would have with just the exhaust and air intake?
Thanks again and great helpful info
Old Sep 23, 2004 | 01:58 PM
spinlocker's Avatar
Donwon9999, I just installed a 6 gun Bundle on my 6spd 03. The stories I could tell. Threads are in the forum ('I just 6 gundmy 03) Mileage came up 10% without trying. Email me at spinlocker@yahoo.com
Old Sep 25, 2004 | 08:55 AM
spinlocker's Avatar
Donwon, thought of something else last night: try this. Disconnect both batteries, turn ignition to "on", leave it that way for about 30 minutes. Turn ignition off, reconnect batteries. Turn ignition "on" but do not start. Slowly press the accelerator to the floor, hold it momentarily, then ease up and let off completely, then turn the ignition "off". Now start the truck. If anything, now your computer will know the range of your gas pedal. Helped mine a little, hey, its a freebie!
Old Sep 28, 2004 | 08:27 PM
bdramsey's Avatar
range of pedal? either that is a really smart computer, or a really dumb computer... depends on how you look at it.
Moobesor
Apr 16, 2008 09:35 PM
Morse
15
Nov 20, 2007 11:44 AM
stevestir
Aug 9, 2006 10:24 AM
yannick
19
May 3, 2004 12:17 AM
BEHRMAN
26
Feb 8, 2004 11:49 AM
