how to get the whistle?
Im curious what i need to make my diesel have that nice loud whistle?
i ordered an aem intake for the truck just waiting for it..dunno if that makes any difference i know nothing about diesels
Thanks guys
Thanks guys
Do a SEARCH for SILENCER RING. Lots of good photos in there also.
I was just like you about a month ago;knew next to nothing. Search has given me a wealth of info on here
Good Luck
Good Luck
take the intake off the turbo. Get a high flow filter. Pull the tube that goes down, about a foot long, off the intake and cut out the baffles (plastic crosshair pieces) and then get the 90 degree bend at the bottom and cut the white junk out of that. Pull the silencer ring off the turbo. Reinstall the intake and it will whistle. mine whistles great.
i got that aem intake for now...how much louder with the whine be?
and was gna get a 4" turbo back exhaust how much of a diff with that make what exhasut to get?
i dont really want to go cutting to much apart if itl void warranty that wouldnt be something i could put back...or id go cut it out..and il probably do the silencer ring
a 06 dually..
i just heard a f250 a while back that whined loud from like 100 yards away you could really here it just whining/whistlin!
and i want that!
and what size exhaust would i run? and would it hurt warranty to have muffler removed?
and i want that!
I think the 06 already has four inch on it so there is no need to replace it. If you alter the exhaust it could mess with the warranty. I thought you were dealing with an older truck. Sorry, guess I should have looked at what forum you posted in.
well ima talk to my guys i wana buy the 5" exhaust for it the intake..im not gonna mess with programmers i dont think i know that for sure voids it.!
bbut gottta have the whistle! and has to be loud!
Thanks guys
Thanks guys
Mine sounds real cool,drives the wife a little nuts though
coobie
Like Coobie says, Make sure you are content with Whistle because you will have it on short trips, long trips, in between trips, & in your sleep!
I did a swiss cheese airbox & got just the right amount. It only does it when your on it hard.
If my wife had to hear it everywhere we went she wouldn't be my wife anymore.
We do lots of things & spend lots of money to get the sounds we want.
Make sure if there is a significant other or someone else that they like the sound as much as you do.
A straight pipe, a missing silencer ring & things like that have probably led
to many homicides!
to many homicides!
replace your silencer tube with this:
and remove your silencer ring. No cutting on anything stock and all replaceable. Putting that AEM intake on will void your warranty faster than removing a silncer ring or tube so don't worry about that. And also, no need to go with a 5" system if your not pushing more than 450hp to the wheels, waste of money. I have stock muffler and intake with no silencer ring or tube and i can hear the turbo pretty decent, add a straight through muffler and an intake and you will get nice whine. probably not quite as much as the stroker you heard for different reasons...
shes got a z28 with slp loud moth off road pipe etc. she loves noise! and races dirtbikes with me! so the noise isnt the problem!
just gotta get the noise! the truck i heard the whine/whistly was loud you could basically just hear it not the motor itself
and i want somethig where i hear the whistle all the time when i drive not just how it is now when i get on it passing someone i hear it.
i want it loud always!
