Hot juice adds timing/ ez adds pressure?
Old Mar 12, 2007 | 08:05 PM
O.T's Avatar
O.T
Ok right now I run the edge hot/juice, looking at a modded cp3 and was advised to add a pressure box. Is there anything to consider before doing this.......
Is it straight forward to stack the ez?
TIA
onetun
Old Mar 12, 2007 | 08:45 PM
RamWheelsBy4's Avatar
Yes the EZ and HOT Juice stack is very good on 04.5 and up. I ran it on mine for pretty good while. The smoothes, most consistent trouble free stack I have ran so far.
Old Mar 12, 2007 | 08:56 PM
O.T's Avatar
O.T
Ram,
Does the EZ harness go first then the HOT?
Thanks
Old Mar 12, 2007 | 09:46 PM
skynyrd's Avatar
yeah into the map the ez goes first then the juice.
Old Mar 12, 2007 | 10:42 PM
973604x4's Avatar
yep good reliable stack
Old Mar 12, 2007 | 10:45 PM
Originally Posted by onetun
Ram,
Thanks
I ran my stack with the Juice plugged into the MAP sensor and the EZ plugged into the Juice pigtail. That is the same way I run my TST and EZ.
Old Mar 12, 2007 | 11:47 PM
O.T's Avatar
O.T
Done went for a burn full guns and saw some improvment for sure through the mid range.
Pressure's are up, I can hold 20k on level 3-4 but Hot pulls down to 13k.
What kind of pressures are you guys seeing?
Old Mar 13, 2007 | 12:49 PM
O.T's Avatar
O.T
Anyone????
Old Mar 13, 2007 | 12:55 PM
omaharam's Avatar
Time for a cp3 upgrade. I was holding 20k with HOT Juice and mp-8 on 60%. Adding the Predator downloader, it will now drop to about 17.5 - 18k for a second or two.
Old Mar 13, 2007 | 12:59 PM
KVD's Avatar
KVD
Would addin a dual feed line help any with the rail pressure drop??
Old Mar 13, 2007 | 04:26 PM
GOT BOOST?'s Avatar
Onetun, i see that you have flux2's, these will hurt your ability to keep the rail pressure up until you upgrade your cp3, that is exactly the reason i am going with flux1's I don't want to have to upgrade the cp3. Also, how much of a difference is there with the HOT juice alone and with the ez. I have been hoping the addition of pressure would really help me out. Hey, also turn your torque setting down real low, like 1 or 2. The torque setting is duration and will hurt your rail pressure as well. Ever slip your OFE yet ? Jay
Old Mar 13, 2007 | 04:48 PM
O.T's Avatar
O.T
ya so I new sooner than later a pump was going to be my next Capital expenditure!!
Running my Juice box on lower settings elimates most pressure drop, I mean I can go full guns on #4 and ez on 1 and hold 20K.
Cruising on any level 22k, hit her hard 180hp HOT ez 1 rail pressure drains to 13k and I can hold that number for 5 seconds or until I see the feds.
Clutch is awsome,
onetun
Old Mar 13, 2007 | 06:26 PM
morkable's Avatar
Even with my 50hp sticks I can drain the rail. CP3 coming
Kevin
Old Mar 13, 2007 | 07:29 PM
GOT BOOST?'s Avatar
mork, what kind of cp3 setup are you looking at? Jay
Old Mar 14, 2007 | 11:16 AM
morkable's Avatar
I am getting a stage 2 from IIs
Kevin
