Homemade 6" Air intake, AKA the "whistler", tech write-up
Old Apr 17, 2007 | 02:08 PM
  #271
Fire Rescue124's Avatar
Question
The Flange is the part that clamps to the pipe on the filter. Correct.
If i did a 45 off the turbo and 4" pipe to another 45 a short pipe to connect the filter to the 45. would that work or should i put 90's on the bends? which do you think would work better?
Old Apr 23, 2007 | 09:31 PM
  #272
53 willys's Avatar
sorry for the late reply.....
I am not sure if it would work??? seems there is not much room for a 45* at the turbo???
I know some have tried a 4" to 5.5" 90*off the turbo and it would not fit..
when you set up a new intake you have to take a gamble and see if it fit's..I was lucky and everything fit perfect.
sorry I could not help more
Old Apr 29, 2007 | 05:47 PM
  #273
53 willys's Avatar
Whistler Stage II Teaser Pics
Well I have a few teaser pics of the whistler stage II set-up...
now keep in mind this is just my prototype version and I have not made any of the lines smooth or clean....I also used some really thin aluminium because I wasted to other good pieces, so the next one you guys see will be A WAY CLEANED UP VERSION OF WHAT IS SHOWN.
let me know what you think
here is a shot of the filter way down in the fender well... nice and cold down here
Old Apr 29, 2007 | 06:07 PM
  #274
Arkapigdiesel's Avatar
Looking good. Did you a buy a 6" to 6" 90 degree elbow to route it down there?
I'd recommend a pre filter down yonder
Old Apr 29, 2007 | 06:19 PM
  #275
53 willys's Avatar
Yep that's what I did.
I know.. I have been saying I am getting one for I while now just have not done it yet
Old Apr 29, 2007 | 07:10 PM
  #276
BigDodgeBigHart's Avatar
What about above the hood?
What about taking the pipe from the turbo and aiming it straight up and cut a hole in the hood with a K&N air filter stick out above it? Then have some kind of hood scoop over the front of it in case of rain, mud or snow? Right now I took the idea here of getting rod of the air box breather and I just have the turbo goto the hose to a 6" K&N air filter, so it whistles like an F18 fighter plane!
But thought of it sticking above the hood, but would I need a hoodscoop? to cover the weather? So it would cover the front of it like a half moon and have the back of the filter above the hood open for air flow and the sound should be louder too! Right? Thanks for any help guys, if I do this I will take pics of it for everyone to see.
Old Apr 29, 2007 | 07:42 PM
  #277
53 willys's Avatar
the hood scoop would be kicked to one side of the hood then and would look weird IMHO....If I had a SRT10 hood I might try to make that work but not with my stock hood.
try it...make sure you post pics if you do.
Old Apr 29, 2007 | 08:35 PM
  #278
I thought of this but I think one will look fine, have been looking for hoodscoops, but nothing on ebay so looking into other websites
Old Apr 29, 2007 | 11:29 PM
  #279
XLR8R's Avatar
This is as close as you can get to having an airfilter poke through the hood w/o having to cut it:
This old photo doesn't show the cowl induction hat that draws air only from the high-pressure cowl plenum.
It's very efficient, and a little loud - balances the 4040L and dump right behind the cab.
Old Apr 30, 2007 | 10:44 AM
  #280
Wow that must be loud!!!! Takes up alot of room eh, but you cannot get anymore wideopen that that breather!!! I thought I would get alot of air cutting through the hood and then putting a workable hoodscoop on it!!
Old Apr 30, 2007 | 11:23 AM
  #281
JP135's Avatar
I may have screwed up... I saw TXOVAL's version of the *****'s and ordered a 4" tube and elbows. Do I need 6" for an 07 with a 5.9?
Old Apr 30, 2007 | 12:35 PM
  #282
What I did for now is just add a 5.5" diameter pipe that is 4 inches long comes straight out from the turbo and put a 5.5" K&N cone filter straight onto it with no curves at all until I decide what I do about the hoodscoop, that is finding the right one, or fabbing one up out of marglass. Still want to stick it straight up through the roof though, the whole K&N, would look mean, but would have to cover it on bad weather which wouldn't look so good eh! The air flow and Whistle would be KILLER!!!!
Old Apr 30, 2007 | 03:04 PM
  #283
53 willys's Avatar
4" or 6" works fine.....6" probably flows more air tho.
Old Apr 30, 2007 | 10:08 PM
  #284
JP135's Avatar
Thanks for the help, guys.
Looking forward to a busy weekend - Ordered my ****** Whistler parts, a muffler delete and a Jake brake.
I'm never gonna get my race car built if I keep messing with the truck!
Old Apr 30, 2007 | 11:21 PM
  #285
53 willys's Avatar
sounds like a fun weekend ahead
