Holley blue pump
Old Mar 26, 2008 | 12:36 AM
dropped2500's Avatar
Holley blue pump
I just installed the Holley blue pump....finally! All i can say is WOW! I should have done that 100 dollar mod a loooooong time ago. Now i can run both boxes all the way up and you better hold on. Only got to play a little bit as it was like 10 when i got done and my stomach was already ****** at me! Im going to try and get some pics when i clean the wires up and add a relay. So for anyone that is thinking of doing an aux lift pump.....its WELL worth it! New clutch next..
Old Apr 6, 2008 | 09:40 AM
booman70's Avatar
Post the pics I was thinking of doin this too. Did you have the intank pump or the canister mounted one if so what did you do on the canister to connect fuel line.
Old Apr 6, 2008 | 01:42 PM
DarrenF's Avatar
My stock cannister mounted pump died, so i added a blue pump back by the tank and just left the stocker inline. Seems to be working fine. No shortage of fuel.
Old Apr 6, 2008 | 05:02 PM
booman70's Avatar
What pressure are you getting and where is your gauge connected if you have one.
Old Apr 6, 2008 | 08:04 PM
DarrenF's Avatar
I don't have a gage mounted in the truck, but i did run a temp gage to verify pressure. It maintained 18 psi at wot on the 140hp setting of my x2. Definatly an improvement over stock, where it would almost instantly run out of fuel.
AlCorr
114
Feb 11, 2009 02:32 AM
Texaschevelle
26
Nov 16, 2007 08:08 PM
ET_178z
Jun 3, 2003 01:15 AM
cpermd
31
Nov 8, 2002 04:13 PM
