high egts
high egts
hey guys today i notised at cruising speed my egt is reaching over1500 im running a smarty sr on 9 pod 55. any ideas? outside temps in the 60s today yesterday no problems outside temps in the 40s
so u r saying, just cruising at light throttle u have those egts? wow, either your guage has gone kaput or1 or more sticking injectors? do u have a heatgun? its another way to see were your temps r at. granted its at idle, but if u have stuck open injectors i would think it would show for sure. good luck in finding out whats up.
btw, if u fill out your sig, we can help u more. what year is your truck? is it an early 05? if so your intercooler is plastic and could of cracked. were is your boost at? im just spitballing a little. in retrospect, i dont think u have stuvk injectors cuz to reach those high egts, just cruising, u would think the truck would be accelerating on its own? IDK. curious
I agree with Rye... take it down to 3 or even stock and try it.
10 psi boost at cruising seems very high as well. 4 is closer to norm.
6 psi fuel pressure before cp3 from a stock pump at cruise is fine as well. As long as you have positive pressure, that is enough.
