HID upgrade question
Old Dec 28, 2009 | 11:13 PM
you da man's Avatar
I'm not the type of person who wants to draw unwanted negative attention to myself so...is there a correct way of upgrading the OEM headlight assembly with an aftermarket HID kit with the proper reflectors to not washout the light and blind drivers? I've changed out the headlight and driving lights with Silverstars and that was a very good improvement vs OEM POS bulbs.
Old Dec 29, 2009 | 07:29 AM
MikeyB's Avatar
There's not much you can do when upgrading to HID. I recommend staying in the 4300-5000 kelvin range for maximum light output instead of the 'look at me' blue and purple colors. Also get a kit that works with computer controlled lighting so the Front Control Module doesn't shut the lights off due to not detecting the proper load. And go with a Bi-Xenon kit, so you can have both low and high beams.
MikeyB
Old Dec 29, 2009 | 08:13 AM
cbrahs's Avatar
ASM makes a good set. I had to get capacitor/resistor blocks to trick the TIPM to stop the low beam flashing/lamp out light
Old Dec 29, 2009 | 05:09 PM
rynemurch's Avatar
My low beams flash how do I stop that? where do I get the stuff ur talking about?
Old Dec 29, 2009 | 09:43 PM
cheadlesram2500's Avatar
I have 6k headlight's and 6k fog lights and I absolutely love them to death
Old Dec 30, 2009 | 05:33 PM
rynemurch's Avatar
What website did u get them at i have 10k but cant use low beams. so i need to buy news ones that come with the extra wire to use low beams?
Old Dec 30, 2009 | 07:02 PM
Pooter's Avatar
I love my 5k kit from hidsolutions, good bang for the buck, install was easy and havent had any issues.
Havent had anyone flash me either, it seems like the '06+ headlights reflect/direct the light better than the '03-05 trucks(comparing my '07 to my old '05)
Old Dec 30, 2009 | 11:27 PM
cbrahs's Avatar
I called these guys http://www.hidspeed.com/
after spending a ton of time researching and crap, i called these guys out of the blue. Told them my problem, I emailed pictures of the connectors I had (many different HID makers use different connectors) and they had my fix custom made for me and at my door in 3 days. No issues at all, love em. and I am at 8000k bi-zenon heads and 8000k fogs
Old Dec 30, 2009 | 11:28 PM
cbrahs's Avatar
no contact the link i posted above. no cutting, no splicing, no tapping, all plug and play. never been happier and they were great to work with
Old Dec 31, 2009 | 01:45 AM
dodgediesel's Avatar
What year of truck do ya have?
Old Dec 31, 2009 | 07:43 PM
spider_1954's Avatar
I have the 6K from HIDspeed and love them. I upgraded the ballast to the mimi's and that took care of the radio static when the lights are on.
You will need the harness with the resistors installed.
Great kits.
82NoMe
35
May 24, 2012 10:58 PM
Rollin'_Coal
Nov 9, 2008 08:31 AM
P.J
Feb 15, 2008 04:03 PM
wcbcruzer
Oct 13, 2007 06:52 PM
deezulsmoke
Jul 9, 2006 09:37 AM
