hey don
Old May 22, 2004 | 05:47 PM
doug60's Avatar
hey don
what it the latest turbo for 600 cummins with tst
Old May 22, 2004 | 08:08 PM
Don M's Avatar
DTR Advertiser
Beta testing one now. Once it lives behind the TST box for a few weeks under heavy thrashing with big injectors, etc. we are going to bolt a few more up to some other rigs here locally.
The compressor wheel is larger than a 40. The turbine wheel is the same size as the 40, but will flow more air because of its design.
Bearings are tougher and were designed to help in the durability area. A complete bolt in kit will be available and will include: a new intercooler pipe, external wastegate, and the fittings to make it all hook up.
Before and after dyno tests are being done Monday!!! The stock turbo has already been dynoed with the pressure box, injectors and the TST. In all different combinations. Monday the tests will all be run again with the new turbo.
Don~
Old May 23, 2004 | 12:46 AM
doug60's Avatar
Great news thanks for the info
Old May 23, 2004 | 09:58 AM
crabman's Avatar
Have you had a look at cams yet Don?
Old May 23, 2004 | 10:08 AM
hoot's Avatar
How are they getting away with the stock turbo on the Dmax over 400 RWHP?
Old May 23, 2004 | 10:25 AM
Idaho CTD's Avatar
Part of the reason is it is water cooled.
Old May 23, 2004 | 10:30 AM
Don M's Avatar
DTR Advertiser
I have a pile of brand new, never ground, camshafts here and no time to grind and test them.
Sometimes I wish I did not need sleep. Then maybe, just maybe I could catch up on these long overdue projects
Old May 25, 2004 | 05:14 PM
Don M's Avatar
DTR Advertiser
Re: hey don
Update: Looks like these turbos are going to work out well. There are a few versions. The first one seems to act about like a HX40 on a second gen. It spools about the same. The dyno is showing a 20 HP gain over the stocker. The EGT reduction is incredible. Much more than a 40 provided on a second gen. Highest EGT recorded today was 1080. This was at 29 PSI using a set of injectors that are just over 100 HP and a pressure box that adds another 40 or so. That is some cool EGT for that HP level. 440 HP!
There are a few othere versions we are working on as well. No data yet.
So far...very good.
Don~
Old May 25, 2004 | 05:24 PM
doug60's Avatar
Thats what we want to hear, thanks for the update, keepum cummin!!
Old May 25, 2004 | 05:46 PM
DAYTRIPPER63's Avatar
Hey can I test/buy /? one I want to use more of my TST but Egt way to hot
Robert
Old May 25, 2004 | 06:49 PM
Don M's Avatar
DTR Advertiser
EGT control is main reason for the turbo. No testing has been done on it with the TST yet. The turbo was installed on the truck this AM and has been run about 50 miles, dynoed, and is now being taken back off to try another. This turbo is heading to the mid west to a test guys place. He is going to run it a few months to see if it lives behind the TST box for extended periods.
It made a 445 HP run today with injectors and a pressure box. 175 HP gain over stock and less EGT
It does spool like a 40 so it is not fast enough IMO for the high altitude guys or auto tranny guys.
The faster spooling unit will be on and dynoed soon.
Maybe a month or two and it will be ready to sell.
Don~
Old Jun 21, 2004 | 09:01 AM
Pushin-No2's Avatar
600 injectors for mileage and power
Hey Don M,
How are the 600 injectors coming along? Will they still work magic even if the turbo isn't changed?
Thanks,
Fred Parlee
Old Jun 21, 2004 | 09:19 PM
Don M's Avatar
DTR Advertiser
Fred,
I am working hard toward a solution, but still dont have it finalized yet. Progress is coming along well though
Old Jun 22, 2004 | 08:20 AM
Pushin-No2's Avatar
injector upgrade
Don M,
Thanks for the reply.
Please let us know when they are ready to fly!
Fred
Old Jul 22, 2004 | 12:51 AM
thejeepdude's Avatar
Originally posted by Don M
Fred,
Hey Don, it's been a month... my truck should be here in 8-12 weeks... how close are we? No pressure or anything!
