Here's a Strange one
Old Dec 15, 2008 | 07:59 PM
Topper's Avatar
Hey guys,
This one comes from a friend of a friend kinda. It seems that he has a 04 that when you put it in gear the truck wants to add fuel and it keep adding fuel untill you put the truck back into neutral. When you put it on a scanner and you look at engine data /calculated load data you can actually watch the load increase and increase untill you can barely hold it back with the breaks. It feels just like your power breaking it. All this without touching the foot feed. It feels like the torque converter is looked but I'm sure that it's not. Driving the truck on the road it feels perfect. In park or neutral it will free rev and come back to and will idle but when it's in gear it just sit there and add fuel untill you put it back into neutral then the engine will rev untill it burns off the fuel and then it will settle down and idle smoothly again. It has some Bullydog extreme or something like that but it does it the same with or without the programmer.
So what do you guys make of this???
Thanks,
Topper
Old Dec 15, 2008 | 08:38 PM
Checkmate's Avatar
hmmm. sounds like the computer thinks its a manual trans.
Gotta be a problem with the torque converter. Has he tried dirvin it like this ?
Old Dec 15, 2008 | 09:02 PM
Spooler's Avatar
It sounds like an APPS problem. Program it back to stock and disconnect the batteries for a 30 min. Hook batteries back up and turn ignition switch to on and mash the go pedal 3 times smoothly all the way to the floor. If you had a scan tool I beat you would see some funky readings while the truck is in gear.
Old Dec 15, 2008 | 09:41 PM
cbrahs's Avatar
torque converter clutch is locking up. we just had one in the dealership this week doing the same thing.
Old Dec 16, 2008 | 03:50 AM
Topper's Avatar
Thanls guys,
Checkmate, the truck drives great.
Spooler, that is what I was thinking.
Cbrahs, that's kinda what we thought at first but the converter seems to be working fine while we are driving the truck. Is it possible that it is particaly locking up? How would I test this?
Thanks!
Topper
Old Dec 16, 2008 | 11:18 AM
SmokinDodge12V's Avatar
I also bet its the convertor Ive seen 2 in the last 6mo in the shop doing the same thing it will still drive ok just hard to stop.
Old Dec 17, 2008 | 09:30 AM
mcolectd's Avatar
This happened to a buddy of mine. Hes also got an 04, and this is exactly like what his did, and it was his torque converter. It drove fine when he let it go, but sitting at a stop light, it would just sit there trying to go like he was power braking it, just pooring out black smoke, and he'd let off the brakes, and itd even chirp the tires a little
Old Dec 17, 2008 | 10:33 AM
HOBrian's Avatar
Seems like this baby wants to run, don't hold her back!
Must be hard to slow down or stop, I would hate to have that in a panic stop!
Old Dec 17, 2008 | 01:19 PM
BossHogg's Avatar
Yep toasted converter! Thats what happend to me so I traded it in for a Gorend trans!
iamallcanadian
Mar 16, 2009 02:57 PM
Flyinhigh79
14
Sep 30, 2005 01:24 PM
Dieseldude4x4
Dec 23, 2002 08:56 PM
Dieseldude4x4
Oct 17, 2002 04:58 PM
