help on turbo and fuel setup
Old Sep 4, 2011 | 01:05 PM
dodgeman1999's Avatar
have an 05 with 100 sticks, 30% over pump and bd special on now and am going to put in 250 sticks questions are do i definatly need dual pumps and twins or will a single 120% over pump work and would a single charger be enough air if so which charger is a daily driver so that plays in to spool up but at same time am reaching for the 900-1000 hp mark thanks for any input
also the truck does have a 3 inch body lift and if i go with twins will they still fit with the body lift
Old Sep 6, 2011 | 08:33 PM
Termite 06's Avatar
For 900-1000 hp I would suggest dual pumps or one of the II dragon fire pumps to keep up with fueling. As for the turbo, if you plan to dd this truck at that power level, you will probably be happiest with twins. A turbo large enough to support that much fuel will probably not have the greatest street manners. You may also want to look into a cam
Old Sep 7, 2011 | 09:13 AM
jhenson's Avatar
^^^^^ agreed.
Thedieselkid
Jul 9, 2008 05:56 PM
Ghost Ram
23
Jan 24, 2008 05:45 AM
ryanihf250
Jan 17, 2008 02:58 PM
n0ne
Sep 26, 2006 11:27 AM
MoparRiggan
Oct 4, 2005 09:43 AM
