Help! Truck Throwing Code Po148
Old Jun 7, 2008 | 08:23 AM
fullthrottle07's Avatar
Exclamation Truck Throwing Code P0148 PLEASE HELP!
The truck is cutting out really bad. I put it back in stock and it is throwing this code: High Pressure Common Rail-Check HPCR Pressure. CODE PO148
Any suggestions on what to do? I had chip in it, the Smarty. And it has the updated version (Revo). It started cutting out so I took the chip off and now its throwing the code.
PLEASE HELP!
Old Jun 8, 2008 | 01:15 PM
FastTaco's Avatar
I had this problem one time also. Ended up being an air leak in a fuel line. Put in a walbro pump and didn't tape one fitting and it sucked air through the threads.
Old Jun 8, 2008 | 02:20 PM
GOT BOOST?'s Avatar
0148 code means that there is a difference between the demanded rail pressure per the ECM and the actual rail pressure measured by the rail sensor. Common problems include inadequate lift pump not supplying the cp3 enough, air in the lines, cp3 problem, FCA problem, leak of the hi p. rail lines, leak between connector tube and injector. I would start at the fuel tank and work foward, measure your fuel pressure before the cp3. I can walk you through the diagnostic process if you would like, pm me. Jay
Old Jun 8, 2008 | 02:44 PM
Totallyrad's Avatar
My lift pump crapped 2 weeks ago, P0628 and P0148 were both there after the truck quit running. Check the filter and lift pump!
rjm022
Jan 22, 2015 10:38 AM
deerledge
18
Sep 10, 2010 03:34 PM
Dnhllmn
Feb 21, 2008 09:17 PM
Sootman
Feb 22, 2004 07:48 PM
