head studs
The head is held on from the factory by bolts that thread into the block through the top of the head. Head studs replace the bolts. They are threaded on both ends and thread into the block and the then a nut is applied to the top threads to hold the head in place. This gives better clamping force and they are made of stronger material as well. The purpose is to eliminate the factory bolts from stretching under high cylinder pressure causing the head gasket to blow.
12valvetom
Nov 27, 2009 11:37 PM
dieselboy59
Jan 30, 2009 03:57 PM
smokewagon
Aug 8, 2008 09:54 PM
MikeThomas
May 11, 2008 11:39 AM
jmccart
21
May 14, 2007 11:47 AM
