Have to say... not impressed with TS SHift master
Old Apr 12, 2009 | 10:15 PM
dfranks's Avatar
Weather was perfect, figured now would be a good time to install my new TS shift enhancer, I bought last fall.
First off, I figured I would check that I have all the parts to complete the install, Nope I'm missing a t-tap so off to the store to buy a t-tap and some wire loom because the wire harness is completely unprotected,(which I think is pretty silly considering the wires may or may not rub on the tranny etc...).
Look at the directions and all that is shown is a close-up pic of a plug that you tap into, no p-shopped arrows to the wires to tap, no pic of where to find the plug (almost on top of the trans BTW) Just a big ol close up of the plug.
OK, I got all the hardware , "Check". Found the plug "Check" mount box on fuse box "Check" All wires from TS harness to tap into plug... WTH ! 2 wires are half the length of the other wires.......
After a couple of hours of messing around, I close my hood and leave this "Plug and play" hardware (as described by TS) to be installed another day.
I'll see if I can get the right harness from TS, but because I live in Canada and bought it Mail order maybe it would be easier and faster to just splice the short wires for my t-taps.
I am sure this hardware works great , just a little frustrated.
*Note to TS* maybe make the harness leads 3' longer and I'll mount the box under my dash out of the elements.
Old Jul 30, 2009 | 02:37 PM
yelloz28's Avatar
What did you think of it once you got it in? I am thinking about putting one on my truck
Old Jul 30, 2009 | 06:43 PM
dfranks's Avatar
Haven't installed it yet.... Just don't have the time. My end up selling it.
Old Jul 30, 2009 | 09:32 PM
no_6_oh_no's Avatar
Get the DTT Shift Enhanser. More bang for the buck and whole lot better track record.
Old Jul 31, 2009 | 12:59 AM
Zeus1987's Avatar
The TS shift enhancer does work. I have had it on my truck now for a couple months. I usually drive around on the tow setting because the race setting hangs onto a gear too long in my opinion. It was kind of a pain to install with the plug right on top of the tranny and all and i did extend the wires and wrapped everything in loom. Overall i am satisfied with it, it does exactly what it is supposed to do.
Old Aug 3, 2009 | 12:57 PM
isb07's Avatar
i had a bad experience with mine i wish i never installed it. first off its wansn't plug and play and was kinda hard to splice the wires on the trans. they also didn't supply enough wire so i had to extend it. i called ts about and were no help and said thats normal and not supposed to reach to the plug on the trans , once installed it worked ok on the 1st setting but the other 2 my trans hunted alot and was a pos, i then took it out and happy with the stock programming again. i wish i never did it now i am worried about the splicing on the trans plug
Old Aug 3, 2009 | 01:53 PM
Breedsrt's Avatar
DTT shift enhancer isnt much better imo. Just my .02 last one i saw looked like something you would find in the bottom of a cracker jack box.
Old Aug 3, 2009 | 02:10 PM
yelloz28's Avatar
I put mine on over the weekend and I am pleased with the results. I was nervous as there seems to be a lot of people that are unhappy with them, but I liked it and it is working fine. Now I can't get the 1-2 hunt even if I try.
Old Aug 3, 2009 | 11:08 PM
thekidfan's Avatar
Sorry, but which one did you install?
Old Aug 4, 2009 | 07:32 AM
yelloz28's Avatar
I put on the TS Shift Master
Old Nov 22, 2009 | 08:59 AM
dfranks's Avatar
While my tranny is out getting a new TC/VB I'll get the installer to splice it for me than we'll see if it works for me.
I am hoping with the new GM solenoid "fix" that it would fix the 1-2 hunt and just increase line pressure in 15lb increments per setting.........( I know DTT's does this)
Old Nov 22, 2009 | 12:16 PM
jgiachino's Avatar
I have the gm solenoid fix and the dtt shift enhancer....no 1-2 issues, but have a 2-3-2 at very light throttle....i gave up and drive around it.
Old Nov 24, 2009 | 06:35 PM
dfranks's Avatar
Do you like the Single disc TC?
Old Nov 27, 2009 | 12:02 AM
jgiachino's Avatar
Yes, i like it....it's pretty tight and got rid of the mushy stock feel, holds the power for 10psi 4x4 boosted launches and is civil for a mechanical dodge trans...it's good piece of mind...would do it over again knowing what i know now.
Old Nov 28, 2009 | 06:15 PM
bobby1stack's Avatar
On mine there is no three settings just a **** that turns not happy with mine at all my .02
