H2 Wheels Again!
Old Oct 17, 2005 | 05:44 PM
guzzirider's Avatar
H2 Wheels Again!
CAN THE TIRES BE BE MOUNTED WHEN THE CENTERS ARE MACHINED
Thanks
Old Oct 17, 2005 | 05:56 PM
Dodgezilla's Avatar
Sure! The problem would lie in if you had opened up the wheel centers with a hole saw like I did not being sure if they are exactly centered. Then the problem will be in getting them balanced. Mounting is not an issue at all.
Jeff K's Avatar
why not. can't see why it would matter.
Old Oct 26, 2005 | 10:32 PM
Patriot_RAM's Avatar
If you're talking about leaving the tires on the wheels while it is machined -- yup. If you can find a lathe that it'll fit on. Hoot used a cnc machine instead and left them on. It worked fine. I removed my tires and had the wheels turned on a lathe. It worked great.
Like he said though, with a hole saw, it won't be perfectly centered which makes it difficult to balance tires.
Old Oct 26, 2005 | 11:42 PM
Raspy's Avatar
Using a hole saw to open up the H2 wheels does NOT affect the balancing. The balancer uses a conical center support to hold and center the wheel on the machine. The wheels have a conical area that matches the balancer cone. The hole saw does not remove this centering taper on the wheels and the balancer does not hold the wheel on the inside of the new (opened up) hole. I recently had mine re-balanced after about 45,000 miles. No problems.
The hole saw method is an easy and quick way to open up the centers, but you should be familiar with using a Hole Hog drill. All you need is a clearance hole since these wheels are lug centered.
Wetspirit
Old Oct 27, 2005 | 01:56 PM
I agree that the wheels are centered by the lugs, but all of the tire balancing machines that I have seen used around here hold the wheel by the inside of the center hole. I guess it depends on the equipment the shop has.
Old Oct 27, 2005 | 07:12 PM
Gas-Man's Avatar
I had a machine shop cut mine on a lathe. They wanted the tires off. I guess it was a small lathe or it just got them out of there way.
Old Oct 27, 2005 | 07:18 PM
ds1rider's Avatar
You would have to have a pretty big lathe to keep the tires mounted. I've never been around one that big.
Old Oct 28, 2005 | 07:38 AM
nickleinonen's Avatar
a milling machine could probably handle the machine work with tires on [i think hoot did it that way]
Old Oct 28, 2005 | 08:37 AM
ds1rider's Avatar
Yeah, a mill could do it, they would just charge more, because the setup takes longer.
Steven K
Jun 4, 2009 10:32 AM
tontof18
Sep 28, 2006 07:59 PM
b84u
Feb 20, 2006 01:04 PM
Sean S
Nov 15, 2002 12:25 PM
