Governor solenoid
Old Mar 13, 2007 | 08:13 PM
RamNu2's Avatar
Governor solenoid
Has any one had a problem with having them taken off and had the tranny not shifting right. I am having a probldem with 1-2 shifts. The transmission seems to be jumping into 2nd then back to first really quickly. Any advise.
Old Mar 13, 2007 | 10:54 PM
973604x4's Avatar
tranny actuator? its especially bad on 06's...but usually its 2-3 shift
Old Mar 14, 2007 | 02:43 AM
THE 0NE's Avatar
i have the same problem and heard the same thing so i am replacing them this weekend ill let you know what happens...
Old Mar 14, 2007 | 12:10 PM
expressfish's Avatar
had the governor and transducer solenoids replaced. tranny would not shift out of 1st.....or would start in third gear. Finally started in 1st again and never came out.
Old Mar 14, 2007 | 03:00 PM
973604x4's Avatar
yep mine did that too.....fried a transducer
Old Mar 14, 2007 | 06:15 PM
bcmopar1's Avatar
Changed mine about hour job works great now!!!!!!!!!!
Old Mar 14, 2007 | 06:25 PM
04smoker's Avatar
When we bump up the line pressure on our 48's it does cause the solenoid to go out prematurely. Replace rapidly!! It can kill your entire trans. I know by experience. However do not be alarmed if this does occur in the next few monthes again. It is a fairly common occurence.
Old Mar 14, 2007 | 07:03 PM
THE 0NE's Avatar
so whats the fix i have a built tranny and it still goes out is their any aftermarket valves?
Old Mar 14, 2007 | 07:47 PM
04smoker's Avatar
Aint the valves. It is the pressure soleniod. I have built trans also. 2weeks after I had the thing go out again 4 the 3rd time. However that was about 7 monthes ago and have had no prolems since. Just know to watch for it. It will cook a built trans if it goes and is not repaired almost immediatly.
Old Mar 14, 2007 | 10:40 PM
THE 0NE's Avatar
is the soleniod in the valve body?
Old Mar 15, 2007 | 12:48 AM
RamNu2's Avatar
Thanks for the heads up about it going bad and to get it fixed quick. I guess in the next two weeks I will have a full built Hts in. Waiting on billet input and hub. I can't wait for it to be done. Next up turbo/'s
Old Mar 15, 2007 | 06:01 AM
rkelley's Avatar
Originally Posted by 04smoker
Aint the valves. It is the pressure solenoid. I have built trans also. 2weeks after I had the thing go out again 4 the 3rd time. However that was about 7 months ago and have had no problems since. Just know to watch for it. It will cook a built trans if it goes and is not repaired almost immediately.
How difficult is it to replace the pressure solenoid and/or transducer? What do the parts cost?
Old Mar 15, 2007 | 07:56 AM
04smoker's Avatar
Very easy to replace the presssure solenoid. Drain the trans pan, remove trans pan, remove the filter. Should be looking at that time for a small round almost looks like a small pill bottle. remove it and disconnect the wiring to it . Reinstall new, fill back up with fluid.
Old Mar 15, 2007 | 07:58 AM
04smoker's Avatar
Oh! Almost forgot the replacement goveror pressure solenoid should cost from the dealer bout 50.00.
Old Mar 15, 2007 | 09:12 AM
rkelley's Avatar
Thanks for the reply. Expressfish said he had the governor and transducer solenoids replaced. Does this imply we need 2 parts or is this the same as the "governor pressure solenoid" part you described?
