Got PS 62/14 Installed Finally
Old Dec 1, 2005 | 11:14 AM
big red psd cc's Avatar
Well got it all buttoned up last night. The guys at Industrial got me the housing via UPS 2day. Being this was the 2nd time doing it, it took about 3 hours in get it out, swap the housings, and re-install. Once you've done it, its amazing how much easier it get
While I was at it, I also added a AFE PG-7 intake.
Old Dec 1, 2005 | 01:11 PM
abc4yew's Avatar
Big, Did you try the 3.2 on the middle setting and the six gun on the lesser settings and the 3.2 on the top setting and the six gun on the lesser settings. I'm sure I've heard of this stack before. The only time it should be a problem is if you get too much timing and the 3.2 doesn't do timing. With added duration You can't have too much rail pressure if your only building 40 psi boost. With those boxes you should have been wastegating some boost. Is your waste gate set to 40psi? Yeah, A TST will be better for you but the 3.2 definitely won't stack with it and the 6 gun would be a ???? Good Luck!!ks
Old Dec 1, 2005 | 02:13 PM
BigBlue's Avatar
I'd send the VA back to them and let them take a look at it.
Old Dec 1, 2005 | 04:10 PM
Lightman's Avatar
This is a stab in the dark, but maybe it has to do with the order in which you install the plugs/harnesses of the two boxes? I know for example with the tst/ez stack, there is a proper way to sequence the plugs..
Old Dec 1, 2005 | 06:20 PM
Agades's Avatar
40 psi right off the bat
ever thought about break in
Old Dec 2, 2005 | 08:04 AM
PanteraGSTK's Avatar
I would really like to hear an answer to this also, because i was thinking about doing this stack.
PowerstrokeThis
May 5, 2011 09:36 PM
mkinla
Feb 6, 2010 12:05 AM
mkinla
14
Feb 6, 2006 10:13 AM
davelinde
Apr 18, 2005 10:26 PM
