Got PS 62/14 Installed Finally
Well got it all buttoned up last night. The guys at Industrial got me the housing via UPS 2day. Being this was the 2nd time doing it, it took about 3 hours in get it out, swap the housings, and re-install. Once you've done it, its amazing how much easier it get :)
While I was at it, I also added a AFE PG-7 intake. |
Big, Did you try the 3.2 on the middle setting and the six gun on the lesser settings and the 3.2 on the top setting and the six gun on the lesser settings. I'm sure I've heard of this stack before. The only time it should be a problem is if you get too much timing and the 3.2 doesn't do timing. With added duration You can't have too much rail pressure if your only building 40 psi boost. With those boxes you should have been wastegating some boost. Is your waste gate set to 40psi? Yeah, A TST will be better for you but the 3.2 definitely won't stack with it and the 6 gun would be a ???? Good Luck!!ks
I'd send the VA back to them and let them take a look at it.
This is a stab in the dark, but maybe it has to do with the order in which you install the plugs/harnesses of the two boxes? I know for example with the tst/ez stack, there is a proper way to sequence the plugs..
40 psi right off the bat
ever thought about break in |
I would really like to hear an answer to this also, because i was thinking about doing this stack.
