Getting 7-800hp with 07?
Gotsmoke.... a couple questions.
What kind of fuel pressure are you running to the duals ?
Besides the smarty... are you using anything else ?
are you only able to stay cool because of the twins & water or do the twins do pretty well on their own ?
Just looking for suggestions/opinions on reaching 700-800hp at the tires on my '07 (5.9). Obviously, theres other mods Id need other than my Smarty, so heres whats planned:
Full billet tranny from Goerend
GDP Fuel Boss lift pump and MK-2 bigline and filter kit
Dual CP3s
Injectors-DDP 90s? maybe
II SilverBullet
Intercooler upgrade
ARP headstuds and probably fire ring head
Whillys Whistler-style intake
That about sums it up. The real question is how to get the extra fuel to stack with my Smarty with the limited number of boxes that are compatible with the '07s. Nitrous is still up in the air, but may do water injection. Truck HAS to be a daily driver, as thats all I have right now. Any input/help/info is appreciated. Thanks
Tim
Dual CP3s
II SilverBullet
Intercooler upgrade
Tim
PPE dual cp3's. DDP90's will work but you will be relying more on the TST so i would advise getting some Flux's from Don M/Formula 1.
If you want big power with one turbo go with the Aurora 5000 from ATS. Banks intercooler setup works well for us out here in Indiana and for the money its a probably the best value.
Many doubted the banks setup but its stood up to 2 years of sledpulling for me at who knows how much boost with the Aurora 5000 turbo.
Dont make any mistakes of messing with O rings or Firerings. Just bottom tap the block when you install the ARP studs and be done with it. Just retorque several times.
I run an AFE stage 2 cone filter.....It gets the job done anything smaller wont do it (ok maybe an old 94-02 stage one filter will).
I dont run any water and my truck has seen 44 hooks to the sled in 4 seasons of SLEDPULLING.
Thats 20-25 seconds at a time of WOT full power.
Last year the truck was right at 600rwhp this year its 675rwhp (dyno proven).
Repeat after me CAM CAM CAM.....SPRINGS SPRINGS SPRINGS!!!
No secrets with my truck either. I use as stock smarty program and an old tst box (3.5 years old) with a twins program.
unfortunately, you're going to need more than that. There aren't any boxes that will get a 07 the correct info it needs to get those numbers. You can take a look at my sig. Even with all that and the smarty I only dynoed at 591hp. That's a great number but, a long ways behind 7 to 800hp. Once I can figure out just what you're asking... I may be close to 700hp. On fuel only though... maybe 550hp to 600hp if I'm lucky but that's pushing it.
Don't get me wrong... I'm sure what you'd like to do can be done but, it takes some know how and lots of tweaking to get there.
Twins I believe are going to be a must and more fuel than you know what to do with... which is where I'm at, at the moment. Spooling is a real pain
What mods only got you 591hp?
Good luck with trying to keep 700-800 hp cool with a single charger. You'll definitely need a medium pair of twins. With the mods in my sig I can't cool them even with spraying water. I do have a 220 psi pump and a 3rd nozzle to put in now and a intercooler and cfm intake horn on order but still thinking about going to a 64/71/13 over a S400. Maybe then with water I'll be able to cool it but have the motor back out now due to melted #6 piston I think from stuck injector or egt's around 1600 degrees? Because of this I didn't get to dyno at Schieds last weekend but if I have enough air maybe close to 700 hp
An SPS66 which is about the same thing you have wouldnt even cool 525hp the right way sledpulling 3 seasons ago for me.
Your really limiting yourself with a 66mm turbo and can cause potential failure of your motor with that small of a charger.
They will work but they will also take their toll on the motor.
What you see in my sig.... completely untuned. The dyno was done about 12 hours after the engine had been started for the first time after it's build. The speed limiter stopped it from pulling in better numbers. I'm sure I should be close to 700hp.
Post a picture of your dyno sheet.
Right off the bat that 64mm is way too small for 700hp. Even if you did manage someday to click 7 on a dyno with a 64 your going to be cooking the engine in short order.
591 is really good for a 64, in fact I would be more than happy with a realistic number like 591 form a 64mm turbo.
Who's the maker on your "HD" rods? I know of mod trucks that run stock rods and they are over 1400hp.
My stock speed limiter if there is one is in place on my engine. Why did it hit 675hp? Does that mean mine would be 800hp?
they're Cummins shot peen rods. I put them in because I was shown a few sets of stock rods that had way less than 1200hp that were split. I didn't want to be in the bottom end again anytime soon. I built the truck to be as stout as I could afford.
You are probably a hair over 600 in my humble opinion. You need to think beyond 66mm turbo as far as single turbo's go. With water maybe 650.
Anyway nice numbers and I do respect them but I'm just not sold on a A5K being all that yet but its probably about the biggest streetable single you can buy and yes my charger is tooooo small for all the fuel I'm pushing.
Tritont don't mean to answer for gotsmoke6 but we don't have motor in his truck yet still sitting in my shop maybe Tuesday since he's camping. Twins should be here then also. He has a tst that doesn't work for crap on his truck probable alot of reason for first motor melt down. His FASS is only a 8# spring as thats what PPE recommended. Also as for your hd rods if you got them thru Schied there shot pinged correct. I can't remember what they told me $1200 or $1400 either way we had a good machine shop balance our bottom ends and ping rods for about half that. I just think the whole Schied thing was a rip the way I found out things after they did my first motor.
I will say Scheid can and does do good work. I met with both the guys that did my build and did appreciate the care they put into getting it right. There's just a lot to be said for the before, during and after service you get.
Scheid wanted to build my engine they way they build them, with their stuff. I wanted something different which kinda rubbed them the wrong way but, it's my money. You wouldn't see half of what's in my sig if it was up to them. Hopefully, because of going outside their box... my engine will hold up a little better.
Thanks for telling me about gotsmokes truck. I'm on an intense search for the correct electronics. The TST is out of the question but, I sure hope they get it worked out !
Ill get some pics up when i get the motor back in.
When she went splat i had a sp pressure box on it also.
Now when i go back together im only gona run the smarty. After $12000 by the time it is done it will just be what it is. I really dont want to build anouther one in a couple of months!!!!!!!!!!!!! With the twins, sticks and smarty it should hopefully be around 650+ so that is my $.02
what was changed? i dont understand. i would like 07s would have more capability than any previous trucks.
