gauges
Old Oct 19, 2011 | 07:33 PM
verdesardog's Avatar
gauges
I finally got my gauges installed today, seems like I didn't really need them. EGT only gets up to about 1000 at 80mph, boost can go as high as 30 and fuel pressure is about 9psi at idle and goes down to about 6 at 80mph. At least I'll be able to keep an eye on fuel pressure so I know when to change the main and 2 micron filters. This is with a Smarty Jr at SW3.
Old Oct 19, 2011 | 07:58 PM
sorry about the quality of the pics, it was getting dark....:
gauges close up
gauges wide view
pyrometer probe
pyometer probe
2micron fuel filter
Old Oct 19, 2011 | 09:15 PM
bobem12's Avatar
Nice work those look dang good! I'm planning on those same factory match gauges soon.
Old Oct 20, 2011 | 03:13 AM
Klickster102's Avatar
where did u get the mount for the gauges?
Old Oct 20, 2011 | 05:57 AM
dodge2005's Avatar
Mine are like verdesardog and I got mine at Diesel Manor. http://www.dieselmanor.com/
Old Oct 20, 2011 | 02:41 PM
I got mine from Geno's garage. I have a new in the box two gauge windshield pod for sale, $20.00 + shipping.
Old Oct 20, 2011 | 04:59 PM
pronstar's Avatar
If you tow, your EGT's will get much higher than that.
And IMHO you should have a tranny fluid temp gauge if you tow.
Old Oct 20, 2011 | 07:27 PM
Dustybowls's Avatar
That fleetguard filter that is in the pic in only a 5micron filter. I think you would be better off with a CAT 0750 or Donaldson P551313. They are both True 2 micron filters...
Awesome setup though
Old Oct 24, 2011 | 04:40 AM
papaduck's Avatar
If you havent already added one, install a water seperator like the Baldwin BF1212. You can put it in front of the tank inside the frame. Also why not add an actual oil pressure guage? The in dash one is a fake and will not let you know if a problem arises soon enough to save the engine.
Old Oct 24, 2011 | 10:11 AM
I know about the dodge fake oil pressure gauge issue. Is there something wrong with the stock fuelfilter/water seperator? My 2micron filter is after the stock one.
You know that cat 0750 is really a 7micron filter, they get 2 microns using pybass specs. I'm getting Donaldson p551313 from now on.
Old Oct 24, 2011 | 05:04 PM
papaduck's Avatar
The 2 mic filter is not a water seperator and the OE filter will remove most water but it really is not adaquite if you get a lot of water. Water is very hard on the injectors. The BF1212 will remove up to 95% of emulsefied water. The OE filter is a good backup but the WIF indicator may not work.
Old Oct 26, 2011 | 05:59 PM
Tori's Avatar
I read that you should have the pyro mounted higher on the manifold, and as far back as possible so your getting the hottest reading. Guess the rear cylinders get the hottest.
Thoughts on that ?
Old Oct 26, 2011 | 10:52 PM
Dustybowls's Avatar
I agree, I added one under the truck.
Old Oct 27, 2011 | 10:22 AM
F1B3R's Avatar
@klickstater. You can get those over head gage mounts from a Viper Srt-10 truck (they come stock in those) and they should mount right up in your truck
Old Oct 27, 2011 | 11:09 AM
thanks, id never seen them before until i saw this post now i know ha i might just have to get some in the future
