Gauges - 2006 Dash Mount?
I've searched all over and visited most of the popular CTD suppliers but can't find what I'm looking for...
I'm looking for a dash mount, under the radio in the bottom (3rd) cubby hole, for 3 gauges. I see them for 05 and down but nothing for the 06 and up. I don't want to loose my grab handle on the A pillar as I like using it to haul my large carcass into the truck.
I have the Quadzilla box and was going to install their nifty Commander but I'm a bit apprehensive about such a permanent setup because of warranty issues, I can pull the computer and harness in a few minutes as it is now but drilling the exhaust manifold and down pipe, not counting all of the wiring involved is pretty much a permanent setup and will not be easy to hide/remove from the dealership.
So I'm must thinking about a set of gauges and keep the simple rotary ****/quick removal setup I have now.
I'd appreciate any input or sources you guys may have.
Thanks,
Thanks,
I just came inside from mounting an Isspro EGT w/an Isspro bullet mount in that same spot. It is facing up towards my head. I will post photos soon. It is against the far left of the cubby hole so the 6 speed shifter does not hit it. I got a boost gauge too, but I can't decide where to put it. In an automatic one could put it right next to the other gauge, but not with a manual.
Thanks,
Thanks,
I contacted Dieselmanor and asked them if they had bullit mounts. They said yes so I got 2 of them, they are made by Isspro as well. Luvnacummins, I am talking about the open area right in front of the shifter boot on a manual transmission. You are right, the knick-knack cubby hole on the 06 is much narrower than the 04 I had.
I am still looking for my camera so I can show you guys.
Shane
NoSparkplugs
17
May 17, 2009 10:36 PM
mmm...diesel
Feb 11, 2009 08:29 AM
4wlow
18
Jan 28, 2009 07:43 AM
PASSMORE
Nov 16, 2006 10:43 PM
estesbubba
Jul 18, 2006 04:35 PM
