Gauge Pods
Old Apr 9, 2011 | 10:56 AM
05 Ram 2500's Avatar
Gauge Pods
Hey All,
I just picked up a 2005 2500 Quad Cab 4x4 and I have a question about Gauges and Gauge Pods. I like the post pods but I don't want to lose the grab bar. I am looking for opinions of the dash or overhead gauge pods. In addition to the stock gauges, which gauges are a must have?
Thanks!
Old Apr 9, 2011 | 12:23 PM
FMB's Avatar
FMB
Best pod in my opinion, is the "over the rear view mirror" pod. Unfortunately, I couldn't keep it from slipping on the glass, and warping the plastic pod in the summer heat. Geno's sent me the A-Post pod, without the grab, but I don't use the grab anyway. I have a 4wd, a Westin nerf bar, and I just touch the steering wheel as I guide my FA up into the seat.
As for gauges, Exhaust Temp, Boost, and either Transmission Temp (if you have an Automatic) or Fuel Pressure (if you have a manual). No rules; just my opinion.
Back to morning brew. . .
Old Apr 9, 2011 | 12:33 PM
firestorm's Avatar
I also have the mirror pod, but mine is the 4 gauge. I am in the install process, so I don't have pictures yet. My gauges include fuel psi, mechanical oil psi, trans temp/ rear end temp dual gauge, and an EGT/boost psi dual gauge. All gauges, except oil psi, are Westech and were purchased from Genos.
Old Apr 9, 2011 | 12:41 PM
firestorm's Avatar
P.S.
If you look at my pictures, you will see these gauges mounted in the pillar pod, of my 01.
Old Apr 9, 2011 | 01:44 PM
rockcrawler304's Avatar
Here is how mine are mounted and keep the grab handle. I still have room for one more.
Old Apr 9, 2011 | 03:33 PM
Thanks for the responses! I was leaning towards the pod above the mirror. Thanks for the info on the gauges as well!
Are there any gauge size clock available?
Old Apr 9, 2011 | 05:12 PM
greasy1's Avatar
Check out lazarsmith.com
Old Apr 9, 2011 | 05:58 PM
Nascarcamper's Avatar
For a real split second there I thought the xmas lights were hanging at the top of the windshield
There is a picture in my gallery of how I did mine and kept the handle... but I don't have the xmas lights
Old Apr 9, 2011 | 09:20 PM
When I first saw that pic on the computer my thought was "wish I could get the xmas lights out of it"
Oh well
Old Apr 10, 2011 | 08:05 AM
Foxborough's Avatar
I mounted my gauges over the mirror and works great. I was told to use RTV silicone (black), it sure worked for me. I used super glue in a few areas to keep the wires hidden too. You mount the pod first then insert the gauges, I used "pin stripe" tape to keep make gauges snug.
Old Apr 10, 2011 | 09:07 AM
Thanks for the picture and the info!
Appreciate it!
Old Apr 10, 2011 | 05:01 PM
EPCO's Avatar
I just installed these. So far I have left the micky mouse mount loose until I am 100% sure I want to keep it there. I wanted a clean dash, but these block the bottom of the instrument cluster if the steering wheel is up, but not down. I pull the wheel down for long hauls anyway.
Old Apr 10, 2011 | 05:26 PM
That is Nice!!!
Old Apr 11, 2011 | 11:31 AM
GumpsVa's Avatar
Just bought new gauges that are factory match but need to dim the lights have mine in triple gauge pod on the door anybody know what wire I can use for dimming off the instrument console?
Old Apr 11, 2011 | 01:39 PM
What year is your truck?
Cbrahs wired mine (2006) and tapped into the dimmer wire. You may want to PM him of nobody else responds. I saw him do it and want to say it is an orange wire behind the fuse panel on the driver side but I could easily be wrong on the color.
