Fuel Rail Pressure Reading
Old Jan 14, 2009 | 11:43 PM
rock crawler's Avatar
My new fuel rail pressure gauge sometimes reads 0 and sometimes reads 5 at idle. What should it read? I wonder if I have a bad gauge. I have it plugged directly into the map sensor before the MP-8. Most of the time it drops to 0 anytime I let off the throttle.
Old Jan 14, 2009 | 11:49 PM
titoheadfaceman's Avatar
How did you plug a fuel rail pressure sensor into a map sensor. And if you are reading 5 on an idling engine, then it is wayyyyyy off
Old Jan 15, 2009 | 02:40 AM
Well, I said map sensor but I meant the fuel rail sensor. And it reads anywhere between 0 and 6k psi at idle. You say that 5k is way off, what should it be?
Old Jan 15, 2009 | 05:15 AM
tesla440's Avatar
You have a lot more mods than I, but for my rail pressure its about 6.6K - 7.1K at idle, Around 18K-20K accelerating, and around 24.5K at WOT.
Old Jan 15, 2009 | 10:00 AM
gmctd's Avatar
Brand and item number??
If you're using the Performax guage, a quick chat with Isspro would be the best course of action - those are like mini-computers on a 17-node intra-net
Old Jan 15, 2009 | 02:37 PM
oh, see I thought you were saying 5psi. Thats about right for idle. usually around 6k or so. But if you say it fluctuates between 0psi and 5000psi, then your gauge must be off. They will not run on anything much below 3000psi.
Old Jan 15, 2009 | 03:08 PM
Thanks guys. I'll give Isspro a call. Maybe it does not read that low. If I bump the throttle it jumps to 6k or higher.
mullishacrew
Mar 18, 2012 12:41 PM
kdbvulcan
Dec 11, 2008 08:53 AM
jlibert
Dec 22, 2007 03:02 PM
5.9Excursion
Dec 11, 2007 11:15 PM
ScottMt02
Jul 27, 2007 07:04 PM
