fuel pressure
fuel pressure
i am doing this for a friend so i haven't read any of the 3gen thread because i have a 2nd gen. but anyways, he has an 06 dually and we put a isspro macanical gauge on his truck and it is reading 9psi at idle and it will go down to 1psi. i think the gauge is wrong because of the diafram. what should the pressure be and where would you put the tap into the line be. we put it on the line going into the fuel pump. do you think the gauge is the problem or do you think it is his truck. i have another gauge for him but he is out of state and i can't change it. he is just calling me and telling me there afraid of his truck blowning up.
I was thinking about getting one of there gauges but do I have to run a fuel line into the cab or is that what the fuel pressure isolator is for? Would like to buy one them but not to fond about having fuel in cab. Could someone tell what to buy so I could stay way from that. Thanks
I run about 9 when idling. I have never seen 1, even when floored towing 16,000lbs up a 9% grade. It would run about 5 doing that. Obviously, the condition of the fuel filter affects the loaded pressure quite dramatically.
Isolators are a inaccurate reading waiting to happen.
Thread started by me a year and a half ago, before I installed the gauges in my old truck:
https://www.dieseltruckresource.com/...echanical+fuel
Here is a poll, I think if someone started another one for JUST the guys that have either an isolator or fuel straight to the back of the gauge (in other words, take out ELECTRICAL) you would find that very, very few people have had issues, the ones that did most likely found out it was due to an error during the install (crimped line, loose compression fitting, etc.)
https://www.dieseltruckresource.com/...highlight=Leak
Mine also idles around 10-11 pounds and will drop to 5 at WOT. I was a little worried about it at first so I talked with my local Dodge tech. He made the comment that the newer trucks don't worry so much about pressure, more about the volume. He stated that 10 is spec and that they can drop down to 2-3 without issues. If below that he said to check FF, if good you have some other issue to find.... like LP.
