Fs-2500
Old Dec 11, 2007 | 12:58 AM
CBD05's Avatar
Fs-2500
i just got it. i have no clue where to mount it. it did not come with the instructions. i got it used from the classifieds. everywhere i look people have it mounted in the engine compartment. it wont mount there with the bracket i have. also the lines are longer than what i have found. is there a frame mount. where do you all have it mounted. i am also looking into buying the engine mount. if i doo i will have to get the hoses also
Old Dec 11, 2007 | 04:13 PM
zuki_dan's Avatar
I sounds like you got the kit that came from the second gen dodges. It mounts on passenger frame rail on those trucks.
I transfered mine from my 2000 dodge to my 06 and kept the long lines rolled up and mounted the filter to the front passenger fender mount behind the fender liner.here is the pic of mine.
http://www.cumminsforum.com/gallery/...500/perpage/12
Old Dec 11, 2007 | 04:19 PM
2rowdy's Avatar
You might try to call them and get instructions for your truck. They seemed like good people when I've talked to them.
Old Dec 11, 2007 | 05:34 PM
CBD05's Avatar
thanks guys. they want an arm and a leg for the bracket and the lines. 248 to be exact! on the frame it goes. it will be easier to change when i have to, but will be a messy job. i dont care though.
Old Dec 11, 2007 | 10:41 PM
bigjohn04's Avatar
I was wandering where a good place was since I have the APPS thanks zuki_dan. Now it's time to order.
Old Dec 12, 2007 | 01:33 AM
Tuf-4x4's Avatar
That goes for me to. Thanks for the info fellas.
Old Dec 12, 2007 | 10:56 AM
05 Thunder Beas's Avatar
Personally I like mine on the frame. Much easier to change for me. I usually have to use a stepladder to work on anything under the hood and so put on the frame it is within easy reach and dosen't make any mess under the hood.
Old Dec 12, 2007 | 04:41 PM
zuki_dan's Avatar
I like mine behind the fender liner, since I pull the fender liner to get to the oil filter any way. With it mounted on the body mount up there it won't leak all over the cp3 when I change the filter. It is also out of the way and won't get damaged.
Old Dec 12, 2007 | 05:11 PM
swalter3's Avatar
What does the oil look like when you guys change it? Every common rail i've seen has been black.
Old Dec 12, 2007 | 09:04 PM
AkitaSumo's Avatar
Every truck that has a 3rd injection event will keep the oil black. It is the size of the particles that the by-pass filters remove. My buddy put one on his 7.3L PS, and it does make the oil look like new on his vehicle...
Old Dec 12, 2007 | 10:43 PM
Megacab07's Avatar
how well would one of them work on a 07
Old Dec 13, 2007 | 12:54 AM
Dieselnick's Avatar
I have FS 2500s for my engine oil and trans fluid; The tranny set-up came with an aluminum mounting bracket, so make sure they send you a steel one so it can be welded onto the frame. It's a lot easier than hogging those 5/8" holes in the frame
Old Dec 13, 2007 | 09:02 AM
AkitaSumo's Avatar
Should work fine...oil will look black be still cleaner than just running the stock filter alone.
Old Dec 13, 2007 | 10:57 AM
elandon1201's Avatar
Go to the website and when you call ask for Chris Williams, He is the R&D guru there and has came up with about 10 different mounting options for the 3rd gen trucks, or send me a PM and I may be able to get you one direct as I know the guy who owns the fabrication shop that makes them for FS2500.
Old Dec 13, 2007 | 11:20 AM
2rowdy's Avatar
My oil was black as coal. I just got my first report back.
oil report 12-12-07.pdf
