Front bumper toast...what to do???
Old Aug 17, 2006 | 01:15 AM
Downeaster's Avatar
Well, I hit a bear this evening on the way to work and destroyed my front bumper. What should I do? Replace with original or go aftermarket.
Old Aug 17, 2006 | 01:39 AM
nchapa's Avatar
the odds of hitting another large animal are against you, I'd get an after market.
45auto's Avatar
Road Armor baby!!
Old Aug 17, 2006 | 07:49 AM
2006 MEGACAB's Avatar
Originally Posted by Downeaster
Well, I hit a bear this evening on the way to work and f***** my front bumper. What should I do? Replace with original or go aftermarket.
Got any pics?? Did the bear die?? I would go aftermarket something beefy
Old Aug 17, 2006 | 08:16 AM
4x4not's Avatar
Yup... unless you are really pressed for cash I'd go adftermarket all the way. When OE crap gets messed up it is always an excuse for an upgrade
Old Aug 17, 2006 | 08:17 AM
Luken's Avatar
Road Armor!
Old Aug 17, 2006 | 08:52 AM
HappyGA's Avatar
romra daor ....
Old Aug 17, 2006 | 08:58 AM
nriver's Avatar
sounds like you are ok
I actually wonder what else is messed up. when I took off my original bumper I found out there is not much to it. if all the bear did was mess up the bumper you are lucky.
my vote is for a buckstop, but they are all good. all depends on the look you want.
there may be other companies closer to you and you could save on some shipping.
my bumper,
Old Aug 17, 2006 | 09:07 AM
Rambunctious1's Avatar
Road Armor
Old Aug 17, 2006 | 09:29 AM
wyosteve's Avatar
Since no one mentioned-- RoadArmor!!
Old Aug 17, 2006 | 09:44 AM
abc4yew's Avatar
My bumper may be fugly but it and the underside skidplates keep everything else safe. Downeaster, does this mean we will be having bear steaks when I get to Machias. There are lots of folks on here with stock bumpers probably in their garage. Mine has repelled two deer so far....Don't know if it would survive a moose but it would do better than stock!! At you time of misery all everyone wants is pictures. The least you need is a good solid brush bar. I had a buddy with a very nice bumper off a d max that he isn't using ....It is a close fit to mine surprisingly but wayyyyy prettier. Kerry
Old Aug 17, 2006 | 10:07 AM
nriver's Avatar
abc4yew
that is one heck of a bumper, nice
Old Aug 17, 2006 | 11:01 AM
abc4yew's Avatar
Nriver, it is build around a solid 6xxx series H beam 10"x8" with 5/8" x 1/2" webs. It is not quite done because I haven't decided on the top style finish or the upright reinforcements. I have a rubber D bumper that goes on the front but I haven't put it on because with the crappy drivers around here I'd probably get in trouble for intentionally using it . Last time it was weighed it was less than 200 pounds and the skids are about 40pounds and the bolts, steel brackets and tow hooks (stock) were about 30 pounds. I hit a fawn on the passenger side and a big doe on the driver side at 65mph. It bent the top corner back 3/8 of an inch.....it was a big hit in my books.....no other damage except some little hoof scratches on the paint. ks
Old Aug 17, 2006 | 11:04 AM
socal 610's Avatar
....I think that 06 road armor is the most ugly thing I've seen look at that buckstop for 06
Old Aug 17, 2006 | 11:19 AM
4x4dually's Avatar
That thing does absoltuely nothing by funnel the deer/bear/cow into your grill and through your condenser/intercooler/radiator.
