freeze plug plate /bypass
Thanks Mark, sorry I misunderstood your previous post.
I agree a bypass would be best, but my truck is quite mild and I would just like to bolt on a plate (or 2!) for now.
I really like the plate in my pic. I hope someone can let me know who makes it and hopefully sells it.
Perhaps a new product idea for you!
...Joe
...Joe
I went with the Enterprise setup too. It comes with an adjustable pressure regulator, so coolant doesn't bypass all the time. It's easy to tell if it is bypassing...even in summer, the truck will never warm up running empty. It will briefly crack the thermostat, get a slug of cold water, and close again.
--Eric
--Eric
I have only a block off plate...and have not had a problem at 4k and 87 psi boost at 1550 degrees.
BUT...
I might do something to free up hp...and relieving uneeded water pressure would do that!
BUT...
Lowering the water pressure will only lower the boiling point of water, it will not free up hp.
Tobin
CTDs have very high coolant system pressure, and blockoff plates for the freeze plugs only allow the pressure to leak past the next weakest point in the water jacket - i.e. the "soft" plugs in the cylinder head.
The ejection pressure on the engine block freeze plugs exceeds 300 lbs.
The less restriction the water pump vanes see...the less hp it takes to drive them...so yes...a bypass relieves water pump drive pressures...which does free up hp.
It was never designed to spin over 3k.
royta
Nov 25, 2016 11:48 AM
Billm2004
19
Mar 24, 2008 10:34 PM
cquestad
May 17, 2007 03:04 PM
Lyall
Sep 7, 2006 06:38 AM
