Free Mod to Remove Speed Limiter for Racing Only!!!
Old Oct 7, 2006 | 08:53 AM
streetsmoker's Avatar
Well, I don't know if anyone who reads this has kept track with my and many others delimma about the speed limiter on our trucks. I had a post going here https://www.dieseltruckresource.com/...d.php?t=118749 and through discussion and a few test runs by some friends, and we can confirm this is absolutely worth while.
Simply remove the 2 ABS fuses from the under hood pannel #6 & #35. You only loose your speedo, everything else works. And you'll be on your way to higher revs and speedier trips!!!!!!
Old Oct 7, 2006 | 08:55 AM
MikeyB's Avatar
Now the only thing you need is install two switches inside the cab for convenience.
MikeyB
Old Oct 7, 2006 | 09:03 AM
iker42's Avatar
Ehh, 2nd Gen Compatable?
Old Oct 7, 2006 | 09:11 AM
I don't know bout the 2nd gens, dont see why not though. Probly just different #'d fuses. As to the switch, only time I'd ever need it is when I'm at the track running slicks, or a street race. There for, not a hassle to do just a few times a month at most. Otherwise, 110-112mph is fine and fast enough for all the other driving I do.
Old Oct 7, 2006 | 09:16 AM
mikmaze's Avatar
lemme guess, good old fashioned brakes to, no abs stopping power/ control........ definately wouldn't want to run this on the street, accident liability...... dang ambulance chasin lawyers< .. >
Old Oct 7, 2006 | 09:54 AM
derek840378's Avatar
people drove for 80 years w/out abs. dont see why i would be a problem.
Old Oct 7, 2006 | 09:57 AM
v8440's Avatar
Yeah, that kinda rates up there with the thread talking about automatic headlights...my take on it is this: DRIVE, stupid! If you can't do that then get off the road.
Old Oct 7, 2006 | 10:01 AM
lmills's Avatar
Mike, there is a wire on the firewall of the second gens that you can clip to get a free fix for the top end limiter. The down side is you lose your cruise control. I can't remeber the wire for sure, but think it was orange and black.
Ask Jetpilot, I think he is familiar with it. You can wire a toggle switch in line and disconnect the limiter on the fly from in the cab
Old Oct 7, 2006 | 05:32 PM
I think this should be in the faq section now, seeing as how it is so easily done.
Old Oct 7, 2006 | 07:35 PM
OT-OF-Here's Avatar
Talking So glad you posted this info
I was having a real major problem with my ATS Co-Pilot and it just didn't work right. The solution was that part of the signal it uses was being captured first by my BD Top Speed Eliminator so I had a choice of one or the other,... RATS!! I took the Co-Pilot. This will give me my Top Speed Elimination back. Tks a bunch.
Old Oct 7, 2006 | 10:26 PM
brickenbone's Avatar
dose it stop the miles from adding up ?
Old Oct 7, 2006 | 11:46 PM
ptgarcia's Avatar
Yeah, does it disconnect the odometer?
Old Oct 8, 2006 | 12:15 AM
DmaxEter's Avatar
Watch out guys. They may close this thread if the "wrong" things start being discussed. Just looking out for ya!
Old Oct 8, 2006 | 08:07 AM
Rick D's Avatar
Could'nt you you a downloader and set the abs tire size up to 40+ inches to raise top speed?? the truck would think it was going slower.
Rick D
Old Oct 8, 2006 | 09:09 AM
Luken's Avatar
Rick D
I've always wondered that myself...Except the other way around. Bigger tires go faster given the same RPM.
