Flux 3.3 record?
Yep, 3.3's dual cp3's, nathan's twins 62/71/13ss over 480, smarty and power puck for electronics. The clutch was slipping all the way, I didn't make good boost, it also spun the tires on the rollers. No correction factor my friend
Dyno was inertia. She's bad. Jay
780 is big HP to 95% of the diesel world, no need to make excuses to justify such a low... hmm... BIG number.
Congrats!
I was there to watch the tires break loose on the dyno. then the clutch slip on the 2nd run. 800hp is definatly possible with 3.3's imo. JP I used 3.3's with a single66 and it get hot!!. I'll let Jay disclose the smarty settings
i was there as well. that truck is sick. i feel there is 800-825 with the electronics on it with a tst a believe it would be alot closer to 900 if not over. we'll see what it can do in the spring everthing will be ready for ts in bowling green.danny
Jay, I did 824 uncorrected with 3.3s over a year ago. It will make more than that though. We only spent a short time working w/ the 3.3s before we moved on to 4.3s. You will probably need a tst though. I was using a tst and smarty beta 4.3 back then/ 64 over 80. Tim
Is it possible to keep 3.3's adequately fed with a single CP3? I mean no problems whatsoever maintaining 27.5k?
Jay, are your CP3's modded at all? I still do not know which way to go. Duals or a st3 CP3.
You told me what I thought but not what the wallet wanted to hear. I may consider cutting back on the injector size to use a modded CP3. I doubt it though as my goal is 750 without N2O
