Fluttering Boost Gauge
I have autometer gauges also (and love them-diehard
). I have twins turbos and my boost gauge will go nuts at times when jumpin' on it.....I read the posts and it makes sense that the wg is open/closing, even thou I have a vacuum wg. Since I've adjusted the wg to keep closed longer, I haven't had the gauge go nuts.
all you want, boost is steady, valve operation doesn't effect the readings on the gauge. I have run 6 different boost gauges in 2 spots on my truck, mechanical and electronic, none fluctuate except at WG operation (especially on a 04.5-07 because of the command valve that applies ~30 psi to a 24psi WG, it slams open, then shut as soon as the command valve closes), but the boost is steady. Even DP is steady, and it has much more pulsing than intake. The only one I had fluctuate was defective.
Did somebody pee in your Wheaties today? Or did you forget your medication...
I just installed a set of Autometer Factory Match Gauges and love them with one exception. The boost gauge is fluttering when I get on it hard at about 30 lbs. What causes this? We tried two different ports, one up front and then moved it to the back and still have the fluttering. Bad gauge?
Thanks guys. I'm new to all this.
Greg.
Greg.
Ditch the banjo bolt and tap the manifold. Being a deleted 6.7 guy I only had to tap the EGR blocker plate.
Gauge is rock solid now...
Ace & AH64ID haven't you A-Holes ever worked on honey dues and don't use a computer for a day or 2??
You got me when I stated vacuum which should of been pressure...But the rest is what I experienced on my gauge, it doesn't flutter at all since I did and adjustment on the wg (mech.).
I knew that's what you meant.
No hard feelings Ace.
The WG on the 04.5-07's is still mechanical, same WG as 03-04, it just doesn't see air all the time, so it can fluctuate pretty hard, otherwise should be smooth.
OneHigh4x4
Sep 28, 2010 10:58 AM
ssleeper94
Nov 7, 2005 08:24 AM
