Fluttering Boost Gauge
I just installed a set of Autometer Factory Match Gauges and love them with one exception. The boost gauge is fluttering when I get on it hard at about 30 lbs. What causes this? We tried two different ports, one up front and then moved it to the back and still have the fluttering. Bad gauge?
Thanks guys. I'm new to all this.
Greg.
Greg.
I'll try a snubber and see if that works any better.
Greg.
Greg.
Greg.
I have found that the intake horn gives high readings, about 2-3 psi high at WOT. This is due to the large restriction in horn. That restriction probably softens the WG effect, but its not the true boost the head is seeing.
My original gauge fluttered a little and then wouldn't go above 25, but the gauge was defective, other than that, I don't see why the head would be different than the intake horn.. possibly a kink in the line that was remove/fixed with the move?? Or just PFM :-)
When getting on it unloaded, she'll get up to 32-33 lbs and flutter hard. How much more boost will I pull when I load the Smarty? I'm waiting a few days until I get some good baseline numbers before loading it.
Greg.
Greg.
Yes, but the pressure should still be fairly uniform. The MAP pressure doesn't change either, as seen on a scanner. Mine is in the bolt closest to the valves, and doesn't flutter one bit.
If you have a Jr it will automatically boost fool, giving you about 32-35 on SW1, and more on the other 2, but I don't have good numbers for them.
If you have a Sr, you need to turn the WG off, and the boost will depend on the tuning.
My personal preference is to keep the boost below 38.
). I have twins turbos and my boost gauge will go nuts at times when jumpin' on it.....I read the posts and it makes sense that the wg is open/closing, even thou I have a vacuum wg. Since I've adjusted the wg to keep closed longer, I haven't had the gauge go nuts.
