Fluidamper install, any tips?
Old Dec 7, 2007 | 03:25 PM
wap's Avatar
wap
Just got my damper today and I hope to have time to put it on tomorrow. I havent read the instructions yet but are there any tips or pointers you guys know of to spead the intall along?
Any help would be great.
TIA
Old Dec 7, 2007 | 03:31 PM
BothellDiesel's Avatar
Wait until you see the difference between stock and Fluidampr . It's a tight squeeze but I did it not removing anything. Someone said not to use locktite just crank'er down.
Old Dec 7, 2007 | 03:33 PM
wap's Avatar
wap
See the differance in each damper or feel and hear the diff once I crank the truck?
Old Dec 7, 2007 | 03:35 PM
enafzige's Avatar
You probably already know, but the belt must be placed over the damper before it's bolted up. I didn't have to remove anything, but it's a little tight.
Have fun! --Eric
Old Dec 7, 2007 | 05:24 PM
53 willys's Avatar
lucky!!!!!!
Old Dec 7, 2007 | 05:33 PM
JCLeary's Avatar
You'll love it! It was one of my favorite mods on my '03!
Make sure you torque it up correctly. The guy who installed mine the first time didn't and the bolts backed out. I had to replace the locating pin in the crank and the tone ring as a result.
A barring tool from Snap-on is a help.
Old Dec 7, 2007 | 05:48 PM
WUnderwood's Avatar
yep, a barring tool is a definate help
Old Dec 8, 2007 | 10:57 AM
wap's Avatar
wap
So maybe I am missing something but the instructions basically say unbolt the old damper and bolt up the new one and torque to 30 or 35ftlbs. I cant remember wich.
What is the locating pin John?
There was something in the instructions about if you are over 3500 rpms you need to drill the crank and use locating pins that came with it but there are non in the box. Just some very gerneral instructions and some stickers.
Old Dec 8, 2007 | 11:24 AM
WUnderwood's Avatar
125 ft lbs
the engine will turn over when you try to tighten the bolts down, that is what the barring tool is for
Old Dec 8, 2007 | 09:43 PM
DODGER BOMBER's Avatar
Ok stupid question here what does the new damper do for performance and what is a barring tool? I have herd of these dampers before and how would it work on my 03
Old Dec 8, 2007 | 10:25 PM
OT-OF-Here's Avatar
Fluiddampr
I've got one. If interested, PM me. Didn't work with my Mitusa.
Old Dec 8, 2007 | 10:51 PM
06 DIESEL's Avatar
You have to order the pins seperately. The damper smothes out the motor, and the barring tool keeps the motor from turning over when tightening the bolts.
Old Dec 8, 2007 | 11:06 PM
PRO-NRA's Avatar
Barring Tool
Is this what you all talking about from Snap On? http://buy1.snapon.com/catalog/item....re&dir=catalog It is only $23.55 so I'll have to get one then. WHere is the best place to bu the Fluidampr?
Old Dec 8, 2007 | 11:14 PM
53 willys's Avatar
this is what a cummins barring tool looks like.....http://www.amazon.com/OTC-Cummins-En.../dp/B00063YWUK
snap-ons....http://buy1.snapon.com/catalog/tools...e=snapon-store
torquefan's Avatar
No, that's not it. This is:
