First problem with custom intake..
Went to change the oil filter yesterday and man what a pain it is trying to get the thick rubber elbow off the turbo to move it all out of the way so I can get the filter out!
It was definitely much easier with the stock rubber boots... I finally got it off and it all went back together easily. The main pain is the nice clamps I bought that have the nut going onto a threaded shaft to tighten the clamp. It just takes forever to get it loose. I may go back to the stock type hose clamps.....
try a deep socket onto a socket drive adaptor for tyour screw gun..... works like a charm, I even yuse it with the 1/2 inch drive adaptor for doing whell changes. break em loose and then power em off with the cordless, 8 lugs a tire gets old fast by hand.
Originally posted by phloop
Try removing the thing from the bottom next. Even though it's tight and a hassel getting to it, it sounds like less trouble than what you just went through.
Ya! I have always just removed the intake hose from between the airbox and the turbo. Then It's very easy to get the oil filter out. It's just not that easy with the H/D rubber boots and the BHAF...
I've never even thought of that. I always just climb underneath and remove it from the bottom. I figure I have to crawl under there anyway to drain the oil so I might as well get the filter while I'm down there.
floridadieselki
Jan 13, 2007 08:51 PM
smkn97s
Jan 13, 2007 09:45 AM
Jmac
May 10, 2004 07:31 PM
