First Mods???
Old Aug 17, 2007 | 04:52 PM
PuffPuff...Gone's Avatar
First Mods???
i just bought an 07 2500 and would like some ideas on exhaust... also any info about chips and intakes is welcome...
Old Aug 17, 2007 | 05:03 PM
snoyes's Avatar
Gauges first... Then you can see if anything you do really helps performance... Also, if you chip it is almost a mandatory item you get an EGT gauge so you don't "over" do it. Do you have the 5.9 or 6.7? With the newer 6.7 it may be more diffifcult to find a good exhaust due to the emissions regen, etc. i think I counted 3 different sensors on that exhaust... manual or auto? maybe need some more info on what exactly your truck is...
Old Aug 17, 2007 | 07:15 PM
CTDinMT's Avatar
I think Edge has come out with a Juice for 6.7's now? Gauges first. I agree with snoyes, your options for a 6.7 are pretty limited right now. Give it time, and I'm sure the performance industry will have lots of stuff available. Now, if you have a 5.9? Lot's of stuff out there for it. Use the search feature and you'll find hours of reading! Oh, and welcome to DTR!
Old Aug 17, 2007 | 07:44 PM
yeah, its a 5.9 still... i really want alot of smoke... any ideas?
Old Aug 17, 2007 | 07:50 PM
CTDinMT's Avatar
Smarty, if they have one for the '07 5.9. Smarty's can black out the sky...
Old Aug 17, 2007 | 08:01 PM
what exatcly is a smarty and what all does it do?
Old Aug 18, 2007 | 09:28 AM
donnee's Avatar
Here is the site that might give you the info.
http://www.madselectronics.com/
Old Aug 18, 2007 | 09:36 AM
farmboykjb5.9's Avatar
you might want to upgrade your tranny/cluth along with your gauges if you want to be able to use the power.
Old Aug 18, 2007 | 10:28 AM
snoyes's Avatar
And the Smarty will black out the sky. And with the deletion of the Torque management you will smoke your transmission with anything above Level 5 (I think the booklet only allows auto to safely run in level 3).
tristan21
Jun 19, 2007 04:57 AM
displacedtexan
15
Mar 2, 2006 10:29 AM
Maddog
Jan 3, 2003 06:17 PM
psalm69
Oct 13, 2002 01:02 PM
