Which firewall plug?
I'm in the process of installing a Quad Standard adjustable performance module and need to go thru one of the firewall plugs. I have a 2004.5 CTD Quad Cab dually.
There appear to be 4 existing plugs. On the left is the steering column plug.
On the far right a lot of wires plus a large bundle of wires go thru a plug.
In between and high is a single plastic wire shroud in a plug. Then in between lower is a solid cable thru a plug.
The plug on the far right appears large and best but is hard to see inside the cab.
Which plug have you used?
Thanks
Thanks
I used the plug where the emergency brake cable runs through. I put a slit in the crease of the plug and have run all wires (Commander, Xzillaraider, and offroad lights) through at that point.
Same here. Cut it a little and it's easy to get to and big enough to run lots of wires thru for all kinds of stuff.
HappyCamper
Jul 3, 2006 10:46 PM
dgibbs
Dec 14, 2005 03:43 AM
