finalizing suspension, wheels, and tires...
i think i am going to go with the superlift 4" kit with the bilsteins with resevoirs for hopefully the best ride possible. I can get the same kit and shocks but fabtech for 250 cheaper. Is the fabtech springs going to ride better then the superlift? atleast I think that is what it boils down to?
Then going to go with 35xXXx18 toyo m/ts on KMC hoss wheels. 18x9 with 5.75 backspacing is what I was told. WIll I have ANY rub?
Thanks for the help and if you just happen to have pics to hold me over till it gets done that would be great!
You'll have absolutely no rub at all with that setup. You could run those wheels and tires with a leveling kit and have no rub. So...... you're in perfect shape there.
As for the kit, I have "heard" that the Fabtech springs ride a little softer than the Superlift springs. Both will be somewhat stiffer than stock though. Shouldn't be that bad.
Your wheel tire set-up will be perfect
I had SuperLift on the 2004.5 and Fabtech on the 2006, they are about the same only I added better shocks (Dirt-Logic) to the 06,
If I had to do it again, I would do a "THUREN" set-up.
Again, nothing wrong with the Super/Fabt kits, but why not go for function and looks at the same time.
POST PICS WHEN YOU ARE DONE
I think I have powertools to spare, seeing how I am the largest milwaukee power tool dealer/distributor in the state of arkansas.
But Im sure I can get a machine shop to do it for dirt cheap and be clean about it. Now just need to quote or find some H2 wheels.
