Fass fuel pumps 95 or 150?
Old Feb 4, 2007 | 12:18 PM
BDS's Avatar
BDS
Which one to buy(95gph/150gph) to support TST box and stock injectors on an 05?...Is the 150 designed for running daul CP3's.
Brent.
Old Feb 4, 2007 | 12:43 PM
Luken's Avatar
I can't help you on the fass but heres another option...
On my 05 I run a GDP 392 kit. It is a pump for every power level.
It supports my truck with a tst/bully dog (660hp) and only loses 2 psi at wide open throttle.
Lucas
Old Feb 4, 2007 | 12:55 PM
Argo's Avatar
I would probably go with the glacier too. I am too lazy to do it though.
Old Feb 5, 2007 | 08:27 AM
Dieselhed's Avatar
Glacier hands down. I installed mine last weekend in about a day, 2 micron filter set up included. Tough to pull down the pressure with this thing even with a heavy foot. Very impressed.
Old Feb 5, 2007 | 09:23 AM
Diesel-Dan's Avatar
150 GPH would be perfect for dual CP3's since higher pressure (from what i have been told) is not really needed. Anything else, the 95 GPH should work just fine for you and can be bumped to 45+psi if wanted.
Old Feb 5, 2007 | 06:35 PM
Coal Train's Avatar
What is needed to bump the pressure up to 45psi?? I have a 150 fass.
Old Feb 5, 2007 | 06:48 PM
Diesel-Dan's Avatar
150 GPH or 150 Series? Or both?
150 GPH cant be run at 45 PSI. Pump was not designed to push that high of a pressure. Its a lower pressure/ high volume pump.
The 95 GPH pump can be run to 80 PSI if needed and flow just a smidge more at 45 psi than the 392 pump. (FASS: 74 GPH to 392: 72 GPH as per our tests) The 95 GPH pump is better for running pressure and it more on par with the Walbro pumps as far as Flow vs. Pressure goes.
rjm022
Oct 20, 2014 02:29 PM
CrashCade
Dec 3, 2008 07:58 AM
dodgediesel
26
Nov 2, 2008 12:20 PM
curts99
Feb 14, 2008 12:09 AM
Ramtuff06
Aug 21, 2007 06:21 AM
