Are FASS and Airdogs reliable?
are they reliable? of course they put out awsome constant psi/volume but are they durable? will they last a few years? has any1 had trouble with theirs?
also once tank is down on the florr is there a vent mod or something i can do to the factory tank vent? i remember a while back hearing about a vent mod that will get you and extra 5 gallons of fuel. is it worth it?
There are 2 different mods you can do while the tank is down.
On top of your stock fuel tank are 2 open "barbs". Some of us have put on some fuel hose and run them to a "T" and run another line up to a fuel filter. It still allows the tank to vent without letting debris, sand, grit, etc a way to get into the fuel tank. (when I did mine it was clean, but some guys have had some problems with dirty tanks in older 3rd gens, like ours)
Here is a thread discussing this... https://www.dieseltruckresource.com/...d.php?t=117209
The other mod is the Vent Tank Mod you are referring to above. It will let you fuel your tank up all the way to the brim without waiting on it to "burp" and make more room for more fuel. It should add about 5 gallons of fuel when you are done by using the unused "expansion" space in your fuel tank. Dodge just uses the same tanks for diesel trucks as Gas powered trucks. Diesel doesn't need the expansion space like the gassers. Here is a couple of sources for the kit. Pretty easy to do. http://www.glacierdieselpower.com/pr...pf_id=0307-TVK
http://www.innertruck.com/store-cate...s_2429930.html
Hope that helps some.
No issues with my AD150 and tank vent mod is shown in the pics in the link in my sig.
I would highly consider one of these:
http://www.idahobombersforum.com/vb/...ght=Draw+straw
http://www.idahobombersforum.com/vb/...ead.php?t=5685
My fully modified cannister should be here mid-week, and I have very high expectation for it to perform wonderfully.....and then I will installed the AD150 along with Glacier's Eliminator bracket
Don't know the Air Dogs.
I think newer FASS units are figured at an honest 500,000+ miles in big rigs.
Should be as good for us. 6 yr warranty. My FASS has been trouble free for 4+ yrs and 125,000 miles.
RJ
RJ
Same here. Didn't do the vent mod, but have had my fass over a year. No problems, and if I have one I pm diesel dan and he responds within a day.
clawson
Jan 12, 2006 08:52 AM
