EZ or XZT
EZ is pressure only.....XZT does some timing too.
The EZ cannot be "off" unless you unhook it from the map and FP sensors.....
The XZT has an off position so you can be stock
The XZT costs the same as an used EZ plus does timing and has cool LED's haha
The XZT is a better buy IMO
When you stack it with the Smarty, select an even number for the smarty program and you'll be good to go!
973604x4 not to derail the thread here, but would you recommend an Edge EZ to try with a BDDL? I am looking for a pressure box to screw around with and am deciding between MP-8 and the EZ. The MP-8 seems more adjustable but other than that I don't know which would be better. And could either be used in conjunction with the Quad Boost Fooler? Thanks
EDIT, NM you just answered it
Here we go:
Bullydog/EZ stack.....Extreme/EZ on 3 netted 14.51 in the quarter mile. Adding the EZ slowed spool up a little...but put a a little kick in the pants when the turbo spooled. it was an OK stack.
Bullydog/MP8.....much more adjustable, more power. Unfortunately don't have track times to compare. The MP8 is more than a pressure box...it does a hair of timing and gets fuel started NOW from the bottom. unfortunately, my MP8 messed up on me....sometimes boost fooling would work, sometimes it wouldn't....i turned the MP8 to 100% once and through a CEL. I called TS and they are currently reprogramming my MP8 with newer software.
I beta tested the boost fooler....and ran it with the BDDL/MP8 stack. It works well. I wouldn't ever consider owning a bullydog without a boost fooler now.
as to which i would recomend...the TS MP8 is the more popular one and does more.....I just hope you don't have the problems I did. If there are problems, TS is very helpful on the phone.
However, the EZ is a solid product, just doesn't perform like an MP8.
Your call...but definitely get a boost fooler.
Lol, you definately sound like an expert, I can't believe how many boxes you've tried.
Boost fooler is already here. I PM'd you about buying one of your MP-8s a week or two ago. You've pretty much convinced me on the MP-8 now so when you get them back be sure to PM me back if you want to sell.
the 06 MP8 is already claimed, obviously!
the other is for an 04.5-05. yes i have spent too much time and money trying different things.....2 programmers, 5 different boxes, a boost fooler (wherever that fits in), and the Edge Attitude and the A2 monitor.....waaaay toooo much
EZ doesn't do boost fooling?
Is that on the 04.5 and up! I thought I put the boost elbow on my 03 so I could go to a higher boost.
I was really considering the EZ for my 05. Should I get a different box? I am not going to the strip just wanna smoke a few ricers and ******** with there windows down are fun tooo....
If you were going to use a pressure module by itself, go with a Quadzilla XZT.
With any of the pressure chips mentioned here, you will not much more if any more smoke than stock.
