ez and bbdl
Old Apr 7, 2005 | 11:28 AM
Bradleysram's Avatar
ez and bbdl
If i were to stack these two plus the outlook monitor, which uses the same mapsensr plug, how would i hook it up. Outlook to the sensor on the block, ez to the outlook, then ez to the factory harnes are just the oposite???
Old Apr 8, 2005 | 09:33 AM
Bud Kunz's Avatar
I would hook the EZ to the sensor side and the Outlook on the Wire side because then the Outlook would still defuel proporly, but I would be careful of that stack because both boxes draw power from the map sensor and could load the trucks power supply. After you hook everything up, look for any boost or map DTCs set before you go out and run it.
notpowerSTROKIN
42
Nov 10, 2007 09:02 AM
PG4x4
Sep 17, 2005 08:04 PM
PG4x4
Sep 16, 2005 09:26 AM
bigthumper
Aug 8, 2004 08:21 AM
Zino
Dec 16, 2003 05:19 PM
