BBDL Outlook Problem
Old Sep 14, 2005 | 08:16 PM
PG4x4's Avatar
I installed my Outlook, and the outlook doesn't power up, the truck looses power and a low boost code comes up.
Any idea's?
There is a yellow wire and a pink wire with a end on it just loose and I don't know what to plug them into. Are they suppost to be left loose for something else?
Old Sep 15, 2005 | 09:33 AM
Bud Kunz's Avatar
The yellow wire should be connected via fuse tape to fuse #28, and the black wire with pink connector is for the old outlook and in the Triple Dog Outlook Application should be left disconnected. Yellow wire is for Power so no wonder it won't power up. Hope that helps man.
Old Sep 15, 2005 | 09:37 AM
STATELINE's Avatar
if you are talking about the bully dog outlook monitor, the only wires on mine that don't simply plug in are for pyrometer, if all else fails READ THE DIRECTIONS
Old Sep 15, 2005 | 10:48 AM
Bud Kunz's Avatar
Talking about the new Bully Dog Triple Dog Outlook. Looks the same as the old but has a couple more connctions. One wire for power and extra harness to go to the OBDII Port.
Old Sep 15, 2005 | 02:49 PM
STATELINE's Avatar
o.k. wasn't aware that they changed the outlook, I have the old one, works the same on my 05 as it did on my 04.
Old Sep 15, 2005 | 06:14 PM
PG4x4's Avatar
Hook the yellow wire up and it worked like a charm. Ty for the help. For the record I read over the install manual 5 times after and it says nothing about a fuse tap. I guess they must of missed that important little detail.
Old Sep 16, 2005 | 09:26 AM
Bud Kunz's Avatar
Yeah, same thing on my first set of instructions, but I called Bully Dog and they sent me an updated set with the important details included.
JKing
Mar 16, 2006 02:49 PM
PG4x4
Nov 16, 2005 07:18 PM
PG4x4
Sep 17, 2005 08:04 PM
Bradleysram
Apr 8, 2005 09:33 AM
