For exhaust sound purposes only
Old May 14, 2008 | 10:02 PM
Eddy Reyes's Avatar
(Not performance) I have tried the exhaust sounds of: Stock mufflers set-up, muffler 36”x 7”, muffler 24”x7”, kitty, no kitty, 12”x5” tip, 24”x 6” tip, etc. And not totally please with the sound. By reading other posts I learn about the better sound of a 5” Turbo back system combine with an after market manifold.
Here is what I am thinking:
Magnaflow 5”, Turbo-back , stainless steel, item # 15986
See it here: http://www.magnaflow.com/02product/s...e=DURA&id=6783
Combine with
ATS manifold, see it here:
http://www.atsdiesel.com/atswebsite/...ExManifold.asp
Opinions and/or experiences are welcome. Thanks.
Old May 15, 2008 | 01:11 AM
bigman's Avatar
I put an 18 inch donalson resonater and 5 inch tail section on my 07. It sounds just like the full 5 inch. Super deep base rumble with out the cackle.
Old May 15, 2008 | 06:26 AM
wap's Avatar
wap
I would think 5" cat back would sount the same as full turbo back, you may could just do a 5" tail section ant that be good enough.
I didnt notice any performance mods, if you do a 5" turbo back you may lose some low end. And I dont know if you will notice much differance in sound with a differnat manifold if you are still runnin a factory turbo.
Just my .02
Old May 15, 2008 | 09:18 AM
JCLeary's Avatar
Combine with
ATS manifolds are nice, but you're still going to have that 3rd gen raspiness once the muffler is broken in unless you run the cat. I even tried two mufflers in line with my '03. Once the mufflers soot up a bit, they get loud.
My plan is to switch to a 2nd gen ATS manifold and a 2nd gen downpipe. Then I'll have some nice bass coming from my exhaust! Big turbo, 2nd gen manifold, custom DP and modified intake. Should make for a nice couple of weekend projects...
Old May 15, 2008 | 09:35 AM
Nsomniac05's Avatar
I have a basic 4" turbo back straightpipe built by a shop back home and it sounded like feces at higher RPM w/ stock manifold and turbo. I have silver bullet and ATS man. now and sounds totally different when you get on it.....
IE-- like a sentra before and a supra now.
BUT my $.02.... the turbo/ manifold install isnt difficult, but it can be tedious and get aggrivating if everything isnt perfect. I recomend not changing your exhaust manifold till you get a new turbo, and do it all at once. It will be a big difference in sound.... and if you really wanna sound cool go with twins, your engine will be slightly quieter with an even deeper tone. and the whistle is awesome.
Also an offroad use cam with NON-IN-CYLINDER-EGR-DURATION-OVERLAP changes the higher rpm sound too but it will affect your emissions.
Old May 15, 2008 | 12:13 PM
staarma's Avatar
I now have a full 5" turbo back system on my truck with no cat and the ATS exhaust manifold along with everything else you see in my sig. I have no raspiness others speak of. It's deep and in command. I did change out the muffler that came with the Flo Pro for a Donaldson 51" and that made the deeper tone along with removing the drone. I'm happy with it where it is now and even towing my toy hauler it's back to where we can converse in the cab again without raising our voices. Wife's happy, everyone's happy.
Hoss
Nov 10, 2012 04:45 PM
hot_runner58
May 3, 2012 06:36 AM
quadman20
Dec 21, 2011 07:06 AM
notpowerSTROKIN
Sep 25, 2007 04:48 AM
Jezzhuntin
Sep 12, 2006 10:50 AM
